    Recalbox 7.0 won't start on rpi0W
    recalbox 7.0 wont start rpi0w
    • benpaj
      benpaj last edited by
      just flash my sd card with last build of Recalbox7 but can't use on my rpi0w. Emu-station really slow to start (30min), after loading i have screen popup that's system configuration are OK but can't do nothing (freeze ?)
      Thanks
      benpaj Zing 2 Replies Last reply Reply Quote 0
      • benpaj
        benpaj @benpaj last edited by
        @benpaj said in Recalbox 7.0 won't start on rpi0W:
        Hello just flash my sd card with last build of Recalbox7 but can't use on my rpi0w. Emu-station really slow to start (30min), after loading i have screen popup that's system configuration are OK but can't do nothing (freeze ?)
        Thanks
          Zing Global moderator Translator @benpaj last edited by
          @benpaj What is your SD card? Is it a class 10?
          Did you download the official image?
          How do you flash the image?
          Is your power supply 5V / 3A?
          I recommend that you download the correct official image for your hardware (Rpi0), flash it with the RASPBERRY PI IMAGER on a 16 GB class 10 SD card (if possible, as using very large SD cards like 128gb can be a problem), and do a test, without modifying anything in the system (do not add ROMS / BIOS / Themes / NOTHING!).
          • benpaj
            @Zing thanks you i think this is the problem. I use an old 4gb micro SD . Think i will buy a new one with min 8Gb and class10
            Many Thanks
