    SummVM and ResidualVM in Recalbox 7
    Emulator Arcade/PC/Console
    summvm residualvm recalbox
    2493
    • jorgemagana
      jorgemagana last edited by
      Hello, is there a change in ScummVM and ResidualVM emulators?
      Since new Recalbox 7 installation I can not run Grim Fandango, is the only game with .residualvm extension. Rest of games with ScummVM extension work without problems.
      Grim Fandango worked perfectly in 6.1.1
      I have a Pi 4.
      qeb 1 Reply Last reply Reply Quote 1
      • suzsuzuki
        suzsuzuki last edited by
        I can confirm this problem
        • lmerckx
          lmerckx last edited by
          What is the problem exactly: game directly returns to the menu ? problem in game ? ...
          For me (RPI3B+ with Recalbox 7), it runs.
          But the controller mapping doesn't worked anymore. It is due to a change in the ResidualVM code.
          I'm investigating ...
          Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
          Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
          suzsuzuki 1 Reply Last reply Reply Quote 0
          • suzsuzuki
            suzsuzuki @lmerckx last edited by
            @lmerckx said in SummVM and ResidualVM in Recalbox 7:
            in pi4 game directly returns to the menu
            • lmerckx
              I think there are major graphical differences between RPI1-2-3 and RPI4.
              And ResidualVM uses a lot of OpenGL(ES) features (unlike ScummVM).
              Perhaps it is the cause of the problem.
              But unfortunately, I have no RPI4. So, I can't help further.
              Sorry.
              • lmerckx
                @suzsuzuki The problem with ResidualVM on PI4 has been identified and will be solved in next version.
                jorgemagana 1 Reply Last reply Reply Quote 0
                • jorgemagana
                  jorgemagana @lmerckx last edited by
                  @lmerckx Thanks! will Grim Fandango be using the new merge (2.2.0) between scummvm and residualvm?
                  • qeb
                    qeb @jorgemagana last edited by
                    @jorgemagana I also have a pi 4 and all scummvm games runs skipping frames unless you move the pointer over the screen.
                    Did you make a fresh install of 7.0.1 or updated from 7?
                    • jorgemagana
                      jorgemagana @qeb last edited by
                      @qeb fresh install
                      • lmerckx
                        lmerckx last edited by lmerckx
                        @jorgemagana The merge between ScummVM and ResidualVM has been done after 2.2 and is still unstable.
                        So no, ScummVM and ResidualVM are still separate.
                        When a stable version is available, it will be integrated in Recalbox.
                        • lmerckx
                          @qeb The lag of ScummVM on PI4 will be solved in next release of Recalbox too (7.0.2, I guess).
                          qeb 1 Reply Last reply Reply Quote 0
                          • jorgemagana
                            @lmerckx thanks.
                            • qeb
                              qeb @lmerckx last edited by
                              @lmerckx great news! I hope it will be released soon 😁
