    P4 4GB versus P4 8GB
    Emulator Arcade/PC/Console
    4gb versus 8gb
    • tdelios
      tdelios last edited by
      I'm debating to buy a 4GB or 8GB Pi4
      There is a $30 difference between the two.
      How much of a significant difference in performance will I notice playing games like PSX, Dreamcast between these two models?
        Zing Global moderator Translator @tdelios last edited by
        @tdelios https://forum.recalbox.com/topic/21373/raspberry-pi-4-y-recalbox-7/
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @Zing last edited by
          @Zing This is not helping. your link is talking about 2GB..
          I'm asking about 4GB versus 8GB Pi4...
          Will I get smoother gameplay with PSX, Dreamcast systems with 8GB than 4GB, or I won't notice a difference?
            paradadf Staff @tdelios last edited by
            @tdelios for the supported systems, more than 2 GB won't give you any significant performance boost. If you care about kodi and 4k resolution, then probably the higher the better.
