    Recalbox 7.0 RPi3B+ several problems
    recalbox 7.0 rpi3b several
    1946
    • n4rcotic
      n4rcotic last edited by
      Hello,
      i'd like to report the following problems that occured with a clean install of RecalBox7.0 on my RaspberryPi3B+:
      • Boot-Videos seem to be a bit zoomed in/cut off at the top & bottom
      • Share partition won't show up when i connect the SD-card via USB-adaptor to my PC (Win10)
      • C64-Games take a looooong time to load
      • Video-Snaps do not play (well i saw them play just once, now even if i reboot the whole system they won't play)
      Think i will test a new and fresh install again..
      • n4rcotic
        Ok, so i tested a new installation, at least the first two problems
        still remaining. Regarding the first one it seems that others also have this problem. I would appreciate any help what i have to do to use the sd-card on my pc to access the share-folder.
        Zing pajarorrojo 2 Replies Last reply Reply Quote 0
          Zing Global moderator Translator @n4rcotic last edited by
          @n4rcotic said in Recalbox 7.0 RPi3B+ several problems:
          I haven't seen any other user reporting this type of problem, possibly the problem is specific, can you test it on another computer?
          Or, can you test it, open disk management on windows 10, and check if the SHARE partition isn't showing up there? If so, you can try to assign a letter to this partition so that it appears in Explorer.
          n4rcotic 2 Replies Last reply Reply Quote 0
          • n4rcotic
            n4rcotic @Zing last edited by
            @Zing
            Assigning a letter to the share-partition via windows 10 disk management was the solution! It does work now, thank you very much!!!
            • n4rcotic
              @Zing
              i totally forgot to ask: will the share-partition be deleted in case of a new installation?
                @n4rcotic I think if you watch this video you will have your answer (I recommend activating the subtitles): https://www.youtube.com/watch?v=skeULeTu7p8&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=23
                • pajarorrojo
                  pajarorrojo @n4rcotic last edited by
                  Same problem here (raspberry pi 3b+)...
                  • F0XHOUND
                    F0XHOUND last edited by
                    Me too in my LG 4K TV
                      @n4rcotic @pajarorrojo @F0XHOUND Please, test what is proposed in this Post, and check if there is any improvement:
                      https://forum.recalbox.com/topic/21515/splash-videos-too-big-for-7-screen
                      n4rcotic 1 Reply Last reply Reply Quote 0
                      • n4rcotic
                        @Zing
                        Thank you very much for your help, i'm sorry it took so long. I tested everything proposed in the Post you mentioned, but it didn't really help. I also changed the values mentioned by Ian to 1920x1080, but that also didn't solve that the boot videos never really fit the screen (i'm using an LG 4K TV btw).
                        I also gather some problems that i still have with RB 7.0, will be finished in two or three days and add them right here.
                          @n4rcotic I recommend you wait a few days, soon the new version of Recalbox will be released, with several bugs fixed, it is more worth waiting and testing the new version ...
