    Infinite restart on RPi 4 4GB
    infinite restart 4gb
    1981
    • ulysess
      ulysess last edited by
      eeeprom: 3 sep.
      SD: tested on 256Gb Samsung and 8 GB Trascend.
      When power on, show this message and then restart in an infinite loop
      alt text
        @ulysess said in Infinite restart on RPi 4 4GB:
        8 GB Trascend.
        remplace your microsd, use sandisk class 10
        and verify your charger.
        ulysess 1 Reply Last reply Reply Quote 0
        • ulysess
          ulysess @acris last edited by
          @acris official charger. Are you saying the microSD quality is the issue about continuously reboot?. First time I hear that in 8 years with a Pi. Tested 2 of them (Samsung Evo) with the same result.
            transcend, samsung , kingston no good for raspberry.
            A lot of freeze with theses company.
            • davidb2111
              davidb2111 Staff last edited by
              Hi @ulysess ,
              Could you post the content of the file /boot/config.txt and give us the type of screen your is connected to? (i.e is it 4k capable, maybe the brand and ref)
              David
              • ulysess
                ulysess @davidb2111 last edited by
                @davidb2111 default config.txt. TV Samsung UE24H4003AW support up to 1080p.
                • ulysess
                  Tested on a 4K Samsung TV and it works. Thanks.
                  • ian57
                    ian57 Staff last edited by
                    @ulysess you can make a test on your 1080p screen and comment the following line in /boot/config.txt
                    # allow 4k 60hz - Comment if fou have a black screen
                    #hdmi_enable_4kp60=1
                    • ulysess
                      weird. That's the stage:
                      • It works: Burn with Balena, eject (not modifying config.txt) and plug/connect the Pi on a Samsung TV 4K. Now I wait 5-10 min. to prepare partitions, power off and connect again the Pi on the TV 24" (resolution is 1080p by default). Everything is fine.
                      • It doesn't work: Burn with Balena, eject (not modifying config.txt) and connect on a Samsung 24" (model UE24H4003AW) and I get infinite loop.
                      I let this comment for future reference or maybe can help someone.
                      • ian57
                        ian57 Staff @ulysess last edited by
                        @ulysess I don't understand you made same things and in 1 case it works, in another one it does not work ?
                        • ulysess
                          ulysess @ian57 last edited by ulysess
                          @ian57 The difference is that in the first one, I plug the Pi on a Samsung TV 4K, wait until I see the UI, and then connect the Pi to the TV 24"
                          • ian57
                            @ulysess I think the next 7.0.1 will fix that. Stay tuned.
                            • davidb2111
                              Hi @ulysess
                              Do you mind making additional tests in PM?
                              David.
