    Moonlight on Recalbox 7 behave strange
    moonlight recalbox behave strange
    6
    15
    3739
    • Zemus
      Zemus last edited by
      Since yesterday i try to make moonlight work, but now i think i dont know what i can do else.
      Pairing works fine, but if i want to start the stream, the rpi4 just cuts off the hdmi signal. On my PC, the Game i want so stream starts, but my TV remains black.
      If i restart ES over the webinterface,TV turns back on and i can see the steam, but now i have the menu-music from ES in the background and i think, i controll the stream and ES parallel.
      I can stop ES, but then after 20 seconds the stream stops.
      What i tried so far:
      Update Geforce Experience and NV-drive to the latest. Before that i used GFE 3.12 and an older NV-Driver, but the result is the same. So i guess this isnt the reason.
      Now i reverted everything back to 3.12, so that my RPI3 can stream.
      If anyone could help me, let me know 🙂
      Zing 1 Reply Last reply Reply Quote 1
        Zing Global moderator Translator @Zemus last edited by
        @Zemus Try this:
        https://forum.recalbox.com/topic/21371/moonlight-on-recalbox-7-0-cant-pair/2
        Zemus 1 Reply Last reply Reply Quote 0
        • Zemus
          Zemus @Zing last edited by
          @Zing I appreciate your effort, but this is my own post xD.
          Additional information: I deleted everything from nvidia with the DDU uninstaller.
          • Zemus
            I did a fresh install of recalbox 7.0.1 but i have the same problem 😕
            • Zemus
              Zemus last edited by Zemus
              OK, i have some new results after a day of testing:
              Recalbox-Version 7.0.1
              Moonlight works with the newest Nvidia driver and Geforce Experience v. 3.20.2.34 (everything greater that Version dont work yet)
              You can download the official release here:
              https://de.download.nvidia.com/GFE/GFEClient/3.20.2.34/GeForce_Experience_v3.20.2.43.exe
              So there is still the Problem with "no hdmi signal until i restart emulationstation via web frontend" ...maybe it could be fixed if moonlight embedded get b*mped to v. 2.4.11
              ...but for now i have to live with it ¯_(ツ)_/¯
              • AnGeReSs
                AnGeReSs last edited by
                Hi Zemus,
                Thank you ! I have the same behavior, and your post helped me but, like you, I need to restart emulationstation for forcing the image ...
                • Pastaga84
                  Pastaga84 last edited by
                  Hi all,
                  I have same problem with Recalbox 7.0.1 and Nvidia Geforce Experience 3.20.2.34
                  Find and Pair : OK but no image when i launch a game on recalbox.
                  Force restart emulationstation interface to get my game...
                  i try to update latest graphics driver, no change 😞
                  Moonlight IOS version works perfectly on my iphone.
                  Maybe should update moonlight version on recalbox
                  • Zemus
                    Zemus @Pastaga84 last edited by
                    @Pastaga84 yeah...i really tried out every possibility for 2 days, so that nobody have to go through the same process.
                    Thanks for the replys.
                    If i would stay alone with it, it maybe never get a priority to fix.
                    • Lamoresk
                      Lamoresk last edited by
                      Hello,
                      I've the same problem with recalbox 7.0.1 and GFE 3.20.5.70
                      Do we need to be part of the dev team to create an issue on gitlab ?
                        Zing Global moderator Translator @Lamoresk last edited by
                        @Lamoresk said in Moonlight on Recalbox 7 behave strange:
                        No, you just need to have a basic Gitlab registration.
                        • AnGeReSs
                          Hello,
                          Do you have any update on this issue ?
                          Or where can we put this issue ?
                          Zing Zemus 2 Replies Last reply Reply Quote 0
                            Zing Global moderator Translator @AnGeReSs last edited by
                            @AnGeReSs Here (but, first research if there is already one on the same subject, it is better to complement an existing one, than to create a new duplicate):
                            https://gitlab.com/recalbox/recalbox/-/issues
                            • Zemus
                              Zemus @AnGeReSs last edited by
                              @AnGeReSs
                              I've opened an issue in Gitlab:
                              https://gitlab.com/recalbox/recalbox/-/issues/1439
                              • Zemus
                                Zemus @Zemus last edited by
                                Error is still the same with 7.1-Reloaded
                                • ElPatator1980
                                  ElPatator1980 last edited by ElPatator1980
                                  Hi dude, I have a similar problem, I tried to ask for help to the french community, but no response : https://forum.recalbox.com/topic/22530/problème-streaming-moonlight-recalbox-7-x-et-retour-es
                                  For me :
                                  • RPI 4 & GFE 3.10.0.95 & Recalbox 7.0.1
                                  • Appairing & game list OK
                                  • TV Screen & game resolution 1080p
                                  • Game started on PC but TV black screen and i can control the game with my controller
                                  • When I quit the game : RPI wait something and i've a black screen
                                  • I did not find any log file
