    "Tremolos" sound with Mame - Recalbox 7
    Emulator Arcade/PC/Console
    tremolos sound mame recalbox
    1174
    • Le Commandant
      Le Commandant last edited by
      Hello all,
      I have a sound problem with Recalbox 7 in Mame.
      Some "tremolos" and bad quality of sound.
      In Recalbox 6.1, I already have the same problem and I had fix it with enable in Retroarch Settings/Legacy /Hard GPU Sync.
      Here, in this version 7, this option is already turned on.
      And I try all settings while hours. I've got always tremolos in sound in all game with Mame.
      I try all emulators versions. Same boat.
      I going crazy with with problem. Any ideas ?
      Thanks by advance and sorry for my poor english.
      • Le Commandant
        I forget this: I use Intel NUC with HDMI out
          Zing Global moderator Translator @Le Commandant last edited by
          @Le-Commandant I have no way to test it now with the new version, but, I already had an audio problem on an x86 PC, with a previous version of Recalbox, and I solved it as follows:
          • Start a game from the emulator in question (MAME);
          • enter the retroarch menu (hotkey + B);
          • Go to Settings;
          • Driver;
          • Audio resampler driver;
          • Change the value from "sinc" to "CC"
          • Save;
          • Close;
          • Restart;
          • Test.
          • Le Commandant
            Thx for your answer. But unfortunately, nothing change with this setting.
            Strange, I even try with other Romset, other version. Same problem.
            I think I try all settings in Audio and Latency options.
            Always sort of sound vibrations making mame unplayable.
            I can not even try an other Audio out, on my Nuc there is only HDMI audio out. I going crazy with this problem.
            Thx again for try 🙂
            • Totogro
              Totogro last edited by
              @Le-Commandant said in "Tremolos" sound with Mame - Recalbox 7:
              I have the same issue with a NUC i3 - D34010WYK.
              I didn't try with the analog output.
                Hello
                before scan your romset with clrmampro with dat/xml file in /bios/mamexxxxx
                1 romset = 1 emulator
                ROMSETS ARCADE :
                MAME => mame 0.78 : core mame2003 (toutes boards, par défaut)
                FINAL BURN NEO + Neo Geo => fbneo 0.2.97.44 : fbneo + neogeo (toutes boards)
                mame + atomiswave + naomi + naomigd => mame 0.220
                Alternatives, en changeant le core par défaut :
                mame 0.037b5 => core mame2000 (pi0/1, pi2, pi3, pi4)
                mame 0.106 => core advancemame (??)
                mame 0.139 => core mame2010 (toutes boards sauf pi0)
                mame 0.160 => core mame2015 (toutes boards sauf pi0)
                mame 2003plus (mix 0.78-0.188) => core mame2003plus (toutes boards)
                romset fba 0.2.96.71 => pifba (pi0/1, pi2, pi3)
