    RP4 4GB Recalbox 7.0 - Naomi does not work
    rp4 4gb recalbox 7.0 naomi does
    8
    10
    2770
    • MarcDK
      MarcDK last edited by
      I finally found the correct bios with the correct md5 hash. But still no naomi game works. It loads and then goes back after I see the pac-man ghosts and returns to the game list. Any idea what is wrong? Or is the pi4 not supported for noami? In that case the unsupported systems should not be visible in the gamelist.
      https://marc.tv
      Scavy Adrikadh 2 Replies Last reply Reply Quote 0
        Scavy Global moderator @MarcDK last edited by
        @MarcDK Check your roms.
        Use the naomi's roms contained in the MAME v0.221 romset.
        It works 😉
        • MarcDK
          @Scavy said in RP4 4GB Recalbox 7.0 - Naomi does not work:
          MAME v0.221 romset
          I will try!
          https://marc.tv
          • Jybe
            Jybe last edited by
            Also, for naomi games I had to found a zip file and a CHD file
            • olivierdroid92
              olivierdroid92 Global moderator @Jybe last edited by
              @Jybe correct.
              Check your set with Clrmamepro
              • 2banditos
                2banditos last edited by
                Worked fine with MAME v0.221 romset! Thanks a lot guys!!
                Btw. is there any list compatibility list which games are working fine ?
                For example Virtua Tennis 1 crashes always while the second Virtua Tennis runs fine
                jorgemagana 1 Reply Last reply Reply Quote 1
                • Adrikadh
                  Adrikadh @MarcDK last edited by OyyoDams
                  @MarcDK please, sent me the bios file please. I cant found it. Contact to me on ****************
                  MODERATION: PLEASE READ FORUM RULES!!!
                  OyyoDams 1 Reply Last reply Reply Quote -1
                    OyyoDams Staff @Adrikadh last edited by
                    @Adrikadh not authorized here for legal reasons.
                    • jorgemagana
                      jorgemagana @2banditos last edited by
                      @2banditos
                      https://github.com/libretro/flycast/issues/136
                      Most of the games start with no issues, the problem is that they are unplayable because of the controls.
                      jorgemagana 1 Reply Last reply Reply Quote 0
                      • jorgemagana
                        jorgemagana @jorgemagana last edited by
                        @jorgemagana said in RP4 4GB Recalbox 7.0 - Naomi does not work:
                        @2banditos
                        Must say: a lot of them are unplayable because of the controls.
