    Recalbox 7.0 on RPi4 - N64 not working for me
    Emulator Arcade/PC/Console
    7.0 recalbox rpi4
    7
    10
    3846
    • acenet
      acenet last edited by acenet
      Hello,
      I did a clean install of Recalbox 7 on RPi4 (unmodified).
      I only registered my 8bitdo SF30 Pro Controllers via Bluetooth.
      N64 roms arent launched at all, I see the Recalbox Screen for 1-2 seconds and then get back to the game list. Tried different ROMs (ByteSwapped, BigEndian, all non zipped). Also tried the different video modes in recalbox.conf, as suggested in other topics. I am using a standard 4K TV via HDMI. Log:
      [2020/10/03 10:10:18.359] (INFO ) : Set 8Bitdo SF30 Pro for player 0 (default)
      [2020/10/03 10:10:18.359] (INFO ) : Configure emulators command : -p1index 0 -p1guid 05000000c82d00000061000000010000 -p1name "8Bitdo SF30 Pro" -p1nbaxes 4 -p1nbhats 1 -p1nbbuttons 16 -p1devicepath /dev/input/event0
      [2020/10/03 10:10:18.359] (INFO ) : Controllers config : -p1index 0 -p1guid 05000000c82d00000061000000010000 -p1name "8Bitdo SF30 Pro" -p1nbaxes 4 -p1nbhats 1 -p1nbbuttons 16 -p1devicepath /dev/input/event0
      [2020/10/03 10:10:18.359] (INFO ) : Shutting down SDL AUDIO
      [2020/10/03 10:10:18.942] (INFO ) : python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc -p1index 0 -p1guid 05000000c82d00000061000000010000 -p1name "8Bitdo SF30 Pro" -p1nbaxes 4 -p1nbhats 1 -p1nbbuttons 16 -p1devicepath /dev/input/event0 -system n64 -rom /recalbox/share/roms/n64/Mario\ Kart\ 64\ (Europe)\ (Rev\ 1).v64 -emulator mupen64plus -core gliden64 -ratio auto
      [2020/10/03 10:10:18.942] (INFO ) : No pad2keyb configuration.
      [2020/10/03 10:10:18.943] (INFO ) : [MQTT] Publishing to tcp://127.0.0.1:1883 from recalbox-emulationstation OK!
      [2020/10/03 10:10:22.276] (WARN!) : ...launch terminated with nonzero exit code 245!
      [2020/10/03 10:10:22.277] (INFO ) : Creating surface...
      [2020/10/03 10:10:22.277] (INFO ) : [MQTT] Publishing to tcp://127.0.0.1:1883 from recalbox-emulationstation OK!
      [2020/10/03 10:10:22.426] (INFO ) : Created window successfully.
      [2020/10/03 10:10:22.446] (INFO ) : Activating vertical sync'
      [2020/10/03 10:10:22.446] (INFO ) : Normal VSync' activated.
      [2020/10/03 10:10:22.446] (INFO ) : Checking available OpenGL extensions...
      [2020/10/03 10:10:22.446] (INFO ) : ARB_texture_non_power_of_two: MISSING
      [2020/10/03 10:10:22.637] (INFO ) : Loaded 21 configuration entries for device 8Bitdo SF30 Pro
      [2020/10/03 10:10:22.637] (WARN!) : Added joystick 8Bitdo SF30 Pro (GUID: 05000000c82d00000061000000010000, Instance ID: 5, Device Index: 0, Axis: 4, Hats: 1, Buttons: 16)
      [2020/10/03 10:10:23.148] (INFO ) : SDL AUDIO Initialized
      [2020/10/03 10:10:23.149] (INFO ) : Loading music /recalbox/share_init/system/.emulationstation/themes/recalbox-next/music/Recalbox Main Theme 06 - SMB - by djpostka.ogg
      [2020/10/03 10:10:23.150] (INFO ) : AudioManager: Theme music found (From theme folder).
      [2020/10/03 10:10:23.150] (INFO ) : Playing Recalbox Main Theme 06 - SMB - by djpostka
      Any suggestions?
      Best Regards
      Andreas
        Hello @acenet
        try another emulator/core.
        Reconfigure your pad in Emulationstation Menu
        • acenet
          Hi,
          unfortunately reconfiguring the pad didn't help. How to change the emulator? Isn't it a disadvantage in terms of performance etc? I guess the best option is configured out of the box, isn't it?
          Best Regards
            Hello @acenet
            try to find and add 64DD_IPL.bin in /bios/ folder, and play again.
              Scavy Global moderator @acris last edited by
              @acris @acenet
              This is an known issue, mupen cores are not lauching, libretro ones do.
              We'll check it.
              • suzsuzuki
                suzsuzuki last edited by
                I have this problem too, 64DD_IPL.bin didn't help
                • ZeBug
                  ZeBug last edited by
                  I have this problem as well. Whichever core I use, the screen comes back to EmulationStation without launching. This seems to be a known problem, because in the N64 rom readme file, it says:
                  " If you have problems about black screen with return to Emulationstation, please read wiki below :
                  https://github.com/recalbox/recalbox-os/wiki/N64-%3A-return-to-ES-(EN) "
                  Problem: the linked page does not exist anymore, as the wiki has been moved. It is therefore very difficult to find the necessary help for this issue.
                  Does anyone have an updated link for this issue?
                  Raspberry Pi 4B 4Gb, SD256Gb, Recalbox 8.0
                  8BitDo SN30pro | Joy-It Armor Case "Block" (passive cooling)
                    Scavy Global moderator @ZeBug last edited by
                    @ZeBug The link is probably a very old one, that has nothing to do with the current bug. There is no solution avaible for instant on this forum !
                    Devs are working on several fixes, this is one of them : wait and look for the upcoming update.
                    @suzsuzuki the N64DD bios doesn't solve the problem. N64 doesn't require any bios.
                    • Samousse
                      Samousse last edited by
                      Pour moi aussi mise à part Mario les autres jeux sont non fonctionnel. Je n'ai pas encore tenté d'autres actions. Je patiente en me replongeant dans la PSX qui sur cette version et mon Pi4 tourne presque mieux que la vrai. enfin je crois c'est loin ....
                      Merci à l'équipe pour le boulot.
                      • countertop
                        countertop last edited by
                        I do have the situation whith N64 on recalbox 7.1.1 that i can only choose between the libreto emulators. i mean, i only see 3 emulator to choose: libreto mupen64lplus, libreto parallel_n64 (wich doesn't work with any rom) and libreto mupen64plus_necxt.
                        Is there any other emulator to choose for n64?
