    [7.0] [x64] Plantage avec GPU RX 570
    [7.0] [x64] gpu 570
    4856
    • Nelzebym
      Nelzebym last edited by
      [    3.040805] [drm] Detected VRAM RAM=8192M, BAR=256M
      [    3.040808] [drm] RAM width 256bits GDDR5
      [    3.042037] [TTM] Zone  kernel: Available graphics memory: 8194952 KiB
      [    3.042041] [TTM] Zone   dma32: Available graphics memory: 2097152 KiB
      [    3.042044] [TTM] Initializing pool allocator
      [    3.042048] [TTM] Initializing DMA pool allocator
      [    3.042083] [drm] amdgpu: 8192M of VRAM memory ready
      [    3.042087] [drm] amdgpu: 8192M of GTT memory ready.
      [    3.042097] [drm] GART: num cpu pages 65536, num gpu pages 65536
      [    3.042480] kvm: Nested Virtualization enabled
      [    3.042487] kvm: Nested Paging enabled
      [    3.042488] SVM: Virtual VMLOAD VMSAVE supported
      [    3.042489] SVM: Virtual GIF supported
      [    3.043717] [drm] PCIE GART of 256M enabled (table at 0x000000F400300000).
      [    3.044717] [drm] Chained IB support enabled!
      [    3.046867] amdgpu: [powerplay] hwmgr_sw_init smu backed is polaris10_smu
      [    3.048813] [drm] Found UVD firmware Version: 1.130 Family ID: 16
      [    3.049785] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
      [    3.053960] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC887-VD: line        _outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
      [    3.053965] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0        /0x0/0x0)
      [    3.053968] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0        /0x0)
      [    3.053971] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
      [    3.053973] snd_hda_codec_realtek hdaudioC1D0:    dig-out=0x11/0x0
      [    3.053975] snd_hda_codec_realtek hdaudioC1D0:    inputs:
      [    3.053977] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
      [    3.053979] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
      [    3.053981] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
      [    3.054970] MCE: In-kernel MCE decoding enabled.
      [    3.056888] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.056891] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.056891]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.056891]  (Note that use of the override may cause unknown side effects.)
      [    3.095258] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:        08.1/0000:0a:00.3/sound/card1/input9
      [    3.095297] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:0        8.1/0000:0a:00.3/sound/card1/input10
      [    3.095329] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/        0000:0a:00.3/sound/card1/input11
      [    3.095395] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:0        8.1/0000:0a:00.3/sound/card1/input12
      [    3.095398] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.095399] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.095399]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.095399]  (Note that use of the override may cause unknown side effects.)
      [    3.095427] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/00        00:00:08.1/0000:0a:00.3/sound/card1/input13
      [    3.099446] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it'        s not patched
      [    3.099452] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it'        s not patched
      [    3.099455] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it'        s not patched
      [    3.099458] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it'        s not patched
      [    3.099461] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it'        s not patched
      [    3.099464] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it'        s not patched
      [    3.099467] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it'        s not patched
      [    3.109379] [drm] DM_PPLIB: values for Engine clock
      [    3.109382] [drm] DM_PPLIB:   300000
      [    3.109384] [drm] DM_PPLIB:   466000
      [    3.109385] [drm] DM_PPLIB:   751000
      [    3.109386] [drm] DM_PPLIB:   1019000
      [    3.109387] [drm] DM_PPLIB:   1074000
      [    3.109389] [drm] DM_PPLIB:   1118000
      [    3.109390] [drm] DM_PPLIB:   1119000
      [    3.109391] [drm] DM_PPLIB:   1120000
      [    3.109392] [drm] DM_PPLIB: Validation clocks:
      [    3.109394] [drm] DM_PPLIB:    engine_max_clock: 112000
      [    3.109395] [drm] DM_PPLIB:    memory_max_clock: 210000
      [    3.109396] [drm] DM_PPLIB:    level           : 8
      [    3.109398] [drm] DM_PPLIB: values for Memory clock
      [    3.109400] [drm] DM_PPLIB:   300000
      [    3.109401] [drm] DM_PPLIB:   2100000
      [    3.109402] [drm] DM_PPLIB: Validation clocks:
      [    3.109403] [drm] DM_PPLIB:    engine_max_clock: 112000
      [    3.109405] [drm] DM_PPLIB:    memory_max_clock: 210000
      [    3.109406] [drm] DM_PPLIB:    level           : 8
      [    3.120677] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.120681] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.120681]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.120681]  (Note that use of the override may cause unknown side effects.)
      [    3.121060] [drm] Display Core initialized with v3.2.48!
      [    3.121175] snd_hda_intel 0000:08:00.1: bound 0000:08:00.0 (ops amdgpu_dm_aud        io_component_bind_ops [amdgpu])
      [    3.146706] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
      [    3.146710] [drm] Driver supports precise vblank timestamp query.
      [    3.152429] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.152434] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.152434]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.152434]  (Note that use of the override may cause unknown side effects.)
      [    3.173492] [drm] UVD and UVD ENC initialized successfully.
      [    3.176437] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.176440] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.176440]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.176440]  (Note that use of the override may cause unknown side effects.)
      [    3.199029] usb 3-3: new full-speed USB device number 4 using xhci_hcd
      [    3.205515] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.205518] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.205518]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.205518]  (Note that use of the override may cause unknown side effects.)
      [    3.228877] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.228880] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.228880]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.228880]  (Note that use of the override may cause unknown side effects.)
      [    3.264435] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.264438] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.264438]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.264438]  (Note that use of the override may cause unknown side effects.)
      [    3.274488] [drm] VCE initialized successfully.
      [    3.275170] kfd kfd: Allocated 3969056 bytes on gart
      [    3.275514] Virtual CRAT table created for GPU
      [    3.275516] Parsing CRAT table with 1 nodes
      [    3.275521] Creating topology SYSFS entries
      [    3.275568] Topology: Add dGPU node [0x67df:0x1002]
      [    3.275571] kfd kfd: added device 1002:67df
      [    3.280815] [drm] fb mappable at 0xE0830000
      [    3.280818] [drm] vram apper at 0xE0000000
      [    3.280820] [drm] size 33177600
      [    3.280821] [drm] fb depth is 24
      [    3.280823] [drm]    pitch is 15360
      [    3.280882] fbcon: amdgpudrmfb (fb0) is primary device
      [    3.293513] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.293514] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.293514]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.293514]  (Note that use of the override may cause unknown side effects.)
      [    3.308689] Console: switching to colour frame buffer device 480x135
      [    3.332473] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.332475] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.332475]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.332475]  (Note that use of the override may cause unknown side effects.)
      [    3.332854] amdgpu 0000:08:00.0: fb0: amdgpudrmfb frame buffer device
      [    3.340593] [drm] Initialized amdgpu 3.35.0 20150101 for 0000:08:00.0 on mino        r 0
      [    3.349815] usb 3-3: New USB device found, idVendor=045e, idProduct=02ea, bcd        Device= 3.01
      [    3.349843] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    3.349863] usb 3-3: Product: Controller
      [    3.349876] usb 3-3: Manufacturer: Microsoft
      [    3.349889] usb 3-3: SerialNumber: 3033363030333236383332363430
      [    3.359794] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.359822] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.359822]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.359822]  (Note that use of the override may cause unknown side effects.)
      [    3.395344] EDAC amd64: Node 0: DRAM ECC disabled.
      [    3.395363] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module        will not load.
      [    3.395363]  Either enable ECC checking or force module loading by setting 'e        cc_enable_override'.
      [    3.395363]  (Note that use of the override may cause unknown side effects.)
      [    3.486141] usb 3-4: new low-speed USB device number 5 using xhci_hcd
      [    3.541241] scsi 9:0:0:0: Direct-Access     WD       Game Drive       5006 PQ        : 0 ANSI: 6
      [    3.541475] sd 9:0:0:0: Attached scsi generic sg2 type 0
      [    3.541639] sd 9:0:0:0: [sdc] Very big device. Trying to use READ CAPACITY(16        ).
      [    3.541765] sd 9:0:0:0: [sdc] 23437770752 512-byte logical blocks: (12.0 TB/1        0.9 TiB)
      [    3.541783] sd 9:0:0:0: [sdc] 4096-byte physical blocks
      [    3.542679] sd 9:0:0:0: [sdc] Write Protect is off
      [    3.542692] sd 9:0:0:0: [sdc] Mode Sense: 47 00 10 08
      [    3.543428] sd 9:0:0:0: [sdc] No Caching mode page found
      [    3.543441] sd 9:0:0:0: [sdc] Assuming drive cache: write through
      [    3.576637]  sdc: sdc1
      [    3.579192] sd 9:0:0:0: [sdc] Attached SCSI disk
      [    3.632883] usb 3-4: New USB device found, idVendor=0e8f, idProduct=2517, bcd        Device= 1.00
      [    3.632910] usb 3-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    3.672870] hidraw: raw HID events driver (C) Jiri Kosina
      [    3.674858] input: Microsoft X-Box One S pad as /devices/pci0000:00/0000:00:0        7.1/0000:09:00.3/usb3/3-3/3-3:1.0/input/input14
      [    3.675018] usbcore: registered new interface driver xpad
      [    3.683789] Bluetooth: Core ver 2.22
      [    3.683821] NET: Registered protocol family 31
      [    3.683834] Bluetooth: HCI device and connection manager initialized
      [    3.683853] Bluetooth: HCI socket layer initialized
      [    3.683868] Bluetooth: L2CAP socket layer initialized
      [    3.683883] Bluetooth: SCO socket layer initialized
      [    3.689348] usbcore: registered new interface driver btusb
      [    3.706994] usbcore: registered new interface driver usbhid
      [    3.707024] usbhid: USB HID core driver
      [    3.709083] input: HID 0e8f:2517 as /devices/pci0000:00/0000:00:07.1/0000:09:        00.3/usb3/3-4/3-4:1.0/0003:0E8F:2517.0001/input/input15
      [    3.761269] hid-generic 0003:0E8F:2517.0001: input,hidraw0: USB HID v1.10 Key        board [HID 0e8f:2517] on usb-0000:09:00.3-4/input0
      [    3.761469] input: HID 0e8f:2517 Consumer Control as /devices/pci0000:00/0000        :00:07.1/0000:09:00.3/usb3/3-4/3-4:1.1/0003:0E8F:2517.0002/input/input16
      [    3.813220] input: HID 0e8f:2517 as /devices/pci0000:00/0000:00:07.1/0000:09:        00.3/usb3/3-4/3-4:1.1/0003:0E8F:2517.0002/input/input17
      [    3.813292] input: HID 0e8f:2517 Mouse as /devices/pci0000:00/0000:00:07.1/00        00:09:00.3/usb3/3-4/3-4:1.1/0003:0E8F:2517.0002/input/input18
      [    3.813363] hid-generic 0003:0E8F:2517.0002: input,hidraw1: USB HID v1.10 Mou        se [HID 0e8f:2517] on usb-0000:09:00.3-4/input1
      [    3.816503] mousedev: PS/2 mouse device common for all mice
      [    4.461658] 8021q: 802.1Q VLAN Support v1.8
      [    4.480896] cfg80211: Loading compiled-in X.509 certificates for regulatory d        atabase
      [    4.482294] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    4.494069] Generic FE-GE Realtek PHY r8169-700:00: attached PHY driver [Gene        ric FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-700:00, irq=IGNORE)
      [    4.584221] r8169 0000:07:00.0 eth0: Link is Down
      [    5.169362] snd_hda_intel 0000:08:00.1: IRQ timing workaround is activated fo        r card #0. Suggest a bigger bdl_pos_adj.
      [    6.783574] squashfs: Unknown parameter 'fmask'
      [    6.783787] FAT-fs (sda2): utf8 is not a recommended IO cha**et for FAT files        ystems, filesystem will be case sensitive!
      [    6.786785] FAT-fs (sda2): Volume was not properly unmounted. Some data may b        e corrupt. Please run fsck.
      [    7.362203] squashfs: Unknown parameter 'fmask'
      [    7.362627] fuseblk: Unknown parameter 'fmask'
      [    7.808785] r8169 0000:07:00.0 eth0: Link is Up - 1Gbps/Full - flow control r        x/tx
      [    8.430860] NET: Registered protocol family 10
      [    8.431187] Segment Routing with IPv6
      [   10.627364] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   10.627366] Bluetooth: BNEP filters: protocol multicast
      [   10.627370] Bluetooth: BNEP socket layer initialized
      [   10.634365] NET: Registered protocol family 38
      Config x64 : Ryzen 1600X, RAM 16 Go, RX570 8Go
      • Nelzebym
        J'ai dû le faire en quatre parties car il y avait trop de caractères pour un seul message !
        • davidb2111
          davidb2111 Staff last edited by
          Merci pour le log 🙂
          Bon, à moins d'avoir du c... das les yeux, j'vois rien d'erratique...
          On continue de chercher...
          • davidb2111
            Si tu arrives à partager une archive de support, je prends aussi
            • Nelzebym
              Bonsoir @Beho , @davidb2111 ,
              J'ai le plaisir de vous annoncer avoir fini par trouver une solution, j'ai tout d'abord tenté de lancer le système sur plusieurs pc avec IGP de la gamme Ryzen (je n'ai pas encore essayé sur mon athlon AM4) ou GPU dédié RX 5XX et le constat était le même.
              J'ai tenté plusieurs flashs différents sur plusieurs support, sans succès.
              J'ai ensuite mis à jour le système sur chacune des versions correctives mais sans succès non plus.
              Enfin j'ai tenté d'abandonner balena etcher au profit de raspberry pi imager et là plus de problème avec mes machines AMD !
              Victoire ! [Imaginez une fanfare de Final Fantasy ici]
              Beho 1 Reply Last reply Reply Quote 0
              • Beho
                Beho @Nelzebym last edited by
                @Nelzebym super c'est vrai que j'ai eu le même problème avec etcher sur la 7.0... mais pas les mêmes symptômes moi j'avais ecran noir. Du coup je suis passé par Rufus. @acris je pense qu'il faudrait arrêter de conseiller etcher pour créer l'image de Recalbox il y a de plus en plus de problèmes avec je trouve (proposition avec ton mon respect bien sûr !!! 😁)
                PC Intel Q9650 4 go de ram Geforce GTX 670 2Go
                Kit borne arcade de chez Fabrikaborne et déco maison
                Kit 2 joueurs Joysticks + boutons lumineux EG Starts (Amazon) et 2 manettes Xbox One
                Ecran 22p 16/9 full hd
                Recalbox 7.1.1 x64
                  @Beho on ne conseille plus etcher depuis la sortie de recalbox 7.xxx
                  mais raspberry pi imager.
                  • Nelzebym
                    Dans les derniers tutos sur youtube de la chaine officielle ça parle encore de balena etcher, mais en effet je suis passé complètement à côté de l'information sur le site !
                      @Nelzebym
                      on a pas refait non plus toutes les vidéos, c'est aussi à l utilisateur de se renseigner un minium et de lire les informations sur les pages 😉
                      on a vu que plus etcher faisait des mises à jour de leur coté plus le flashage devenait merdique.
                      On a agi en conséquence, pour indiquant partout de ne plus flasher avec etcher mais raspberry pi imager dont recalbox a été intégré il y a peu aussi.
                      tu installes raspberry pi imager, tu cherches recalbox dans la liste et voila.
                      • Beho
                        Beho @acris last edited by
                        @acris ou super je n'avais pas vu. Vous êtes top !
                        Recalbox 7.1.1 x64
                        • Nelzebym
                          J'oubliais le plus important, merci à tous pour votre aide 🙂
                          100.3k
