    Games crash when USB Gamepad plugged
    crash usb gamepad plugged
    • Cypher84
      Cypher84 last edited by
      Hello,
      I have an issue with my recalbox.
      Games are not working when my USB Gamepad (N64) is plugged.
      I've tried the default games, downloaded games, nothing is working.
      No error message, i launch the game, and the system is back to games select.
      Every games are working when my Gamepad is unplugged.
      And... I can't execute the recalbox-support.sh script, because i can't login on the rpi.
      I tried via SSH :
      ssh root@recalbox
      ssh: connect to host recalbox port 22: Resource temporarily unavailable
      Recalbox Version : 6.1.1 DragonBlaze
      Rpi 3B +
      I think it's a difficult question, especially without any logs but...
      If anybody can help me... And if everybody can excuse my english, i'm trying my best x)
      Cheers.
        Zing Global moderator Translator @Cypher84 last edited by
        @Cypher84
        Did you build your Recalbox yourself, or did you buy everything ready, or did you download a ready image from the internet?
        Did the Joystick never work in Recalbox, or did it, and stopped working?
        Have you ever tried to remap the controller on the Emulationstation?
        Did you do this test using a keyboard, or, another joystick?
        If the joystick never worked, and it works without it, it may be incompatible drivers, and if so, there is no solution.
        Cypher84 1 Reply Last reply Reply Quote 1
        • Cypher84
          Cypher84 @Zing last edited by Cypher84
          Hi, thank you for trying to help me sir.
          @Zing said in Games crash when USB Gamepad plugged:
          @Cypher84
          I've downloaded from https://archive.recalbox.com/ and i've used baleneEtcher for installation on microSD
          The Joystick never worked
          Yeah, At startup, I mapped the joystick buttons. But, the wizard seems to provides only SNES buttons. Can't map the Z button of N64, for example. Maybe there is a relationship between this and my issue ?
          Yeah, i've bought 4 Joystick. Same result with all of them. But, with just the keybord, all games works.
          The joystick is sold as rpi compatible, bought on a serious french e-commerce (LDLC).
            Zing Global moderator Translator @Cypher84 last edited by Zing
            I don't have enough knowledge about these joysticks to help you, maybe these links will help you:
            https://forum.recalbox.com/topic/9016/a-lire-manettes-n64
            • Cypher84
              I think it's going to be a lot simpler with config files, thank you, didn't see this topic !
              I try after work and let you know.
              Thank you mate.
