    How to change language settings for RetroArch? (6.1.1 DragonBlaze)
    language settings retroarch 6.1.1 dragonblaze
    19085
    • flux
      flux last edited by
      How do I access the language settings for RetroArch? The RetroArch menus are in French, but all the language settings in recalbox.conf have been set to US English. I would like the RetroArch menus to be in US English. Here is what my config file looks like:
      # System Variable
      system.power.switch=PIN356ONOFFRESET    # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
      ## fbcp FrameBuffer Copy Program
      ## For small TFT screen on GPIO and SPI
      ## See https://github.com/recalbox/recalbox-os/wiki/Utility---Use-of-fbcp-for-small-TFT-screen-%28EN%29 for details
      ## Needed for Waveshare 3.2" 3.5" TFT screen, 2.8" Adafruit screen
      ## See https://github.com/recalbox/recalbox-os/wiki/TFT-Screen-SPI-Bus-%28EN%29
      ## for support and configuration details needed by /boot/config.txt
      system.fbcp.enabled=0
      ## Splash screen duration
      ## 0: Video will be played for 20 seconds (default)
      ## -1: All the video will be played (it won't be stopped automatically)
      ## >0 : Time before the video will be stopped (in seconds)
      system.splash.length=0
      system.manager.enabled=1
      ## Currently, only version 2 is available
      system.manager.version=2
      ## Recalbox security
      # enforce security
      # samba password required
      # disable virtual gamepads
      system.security.enabled=0
      ## Recalbox API (REST)
      system.api.enabled=0
      ## Allow a specific resolution for ES only from the command : tvservice -m [MODE]
      ## Leave commented for the default usual behaviour
      ;system.es.videomode=CEA 4 HDMI
      ## EmulationStation
      ### menu style
      ### default -> default all options menu
      ### none -> no menu except the game search menu
      ### bartop -> less menu, only needed for bartops
      emulationstation.menu=default
      ### Select a system to show on boot (use rom directory name) (string)
      emulationstation.selectedsystem=favorites
      ### Show the gamelist of the first or selected system on boot (0,1)
      emulationstation.bootongamelist=0
      ### Disable system view. ES will boot and show ONLY the first or selected system (0,1)
      emulationstation.hidesystemview=0
      ### Pa**e Gamelists only. Show only games listed in gamelist.xml files (0,1)
      emulationstation.gamelistonly=0
      ### Force basicgameList view to be displayed, even if your game systems are scraped (0,1)
      emulationstation.forcebasicgamelistview=0
      ## Videosnaps
      ### Delay before videosnaps start, in millisecond. Default: 2s
      ;emulationstation.videosnaps.delay=2000
      ### Video loop times. 0 = no video. 1 or more = the video loops x times before fading out
      ;emulationstation.videosnaps.loop=1
      ## Scrapers
      ### ScreenScraper.fr
      ### Force media region - if not defined, region is taken from system.language. Default: us
      ;scraper.screenscraper.region=us
      ### Force text language - if not defined, region is taken from system.language. Default: en
      ;scraper.screenscraper.language=us
      ### Choose the media to download among:
      ### screenshot: game screenshot
      ### title     : game title screenshot
      ### box2d     : Front case
      ### box3d     : 3D rendered case
      ### mixv1     : Recalbox special mix image V1 (default)
      ### mixv2     : Recalbox special mix image V2
      ;scraper.screenscraper.media=mixv1
      ### ScreenScraper account
      ;scraper.screenscraper.user=
      ;scraper.screenscraper.password=
      ## Emulator special keys
      kodi.enabled=0
      ## Start kodi at launch (0,1)
      kodi.atstartup=0
      kodi.xbutton=0
      ## Allow a specific resolution for Kodi only from the command : tvservice -m [MODE]
      ## By default is using the default resolution of your screen
      kodi.videomode=default
      ;kodi.network.waittime=10
      ## Hyperion
      ## Hyperion allows you to use an ambilight like led system on your recalbox
      ## Use hypercon to create your configuration file, and copy it in /recalbox/share/system/configs/hyperion/hyperion.config.json
      hyperion.enabled=0
      ## Set system hostname
      system.hostname=RECALBOX
      ## Activate wifi (0,1)
      wifi.enabled=1
      ## Set wifi region
      ## More info here: https://github.com/recalbox/recalbox-os/wiki/Wifi-country-code-(EN)
      wifi.region=US
      ## Wifi SSID (string)
      wifi.ssid=the green rabbit
      ## Wifi KEY (string)
      ## after rebooting the recalbox, the "new key" is replace by a hidden value "enc:xxxxx"
      ## you can edit the "enc:xxxxx" value to replace by a clear value, it will be updated again at the following reboot
      wifi.key=fluxbunny2008:)
      ## Wifi - static IP
      ## if you want a static IP address, you must set all 3 values (ip, gateway, and netmask)
      ## if any value is missing or all lines are commented out, it will fall back to the
      ## default of DHCP
      ;wifi.ip=manual ip address
      ;wifi.gateway=new gateway
      ;wifi.netmask=new netmask
      # secondary wifi (not configurable via the user interface)
      ;wifi2.ssid=new ssid
      ;wifi2.key=new key
      # third wifi (not configurable via the user interface)
      ;wifi3.ssid=new ssid
      ;wifi3.key=new key
      ## Samba share
      system.samba.enabled=1
      ### Virtual Gamepads
      ### SSH
      system.ssh.enabled=1
      audio.device=auto
      ## Set system volume (0..100)
      audio.volume=92
      audio.bgmusic=1
      # Enable ERTM
      controllers.bluetooth.ertm=0
      controllers.ps3.enabled=1
      ## Choose a driver between bluez, official and shanwan
      ## bluez -> bluez 5 + kernel drivers, support official and shanwan sisaxis
      ## official -> sixad drivers, support official and gasia sisaxis
      ## shanwan -> shanwan drivers, support official and shanwan sisaxis
      controllers.ps3.driver=bluez
      # ------------ D2 - GPIO Controllers ------------ #
      ## GPIO Controllers
      controllers.gpio.enabled=0
      controllers.gpio.args=map=1,2
      ## Custom mk_gpio arguments,
      ## map=5 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk  for one controller,
      ## map=5 gpio1=pin1,pin2,pin3,.....,pin12,pin13
      ## map=5,6 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk gpio2=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk for 2 (map=5,map=5,6)
      ## map=5,6 gpio1=gpiox,gpioy,gpioz,.....,gpiou,gpiov gpio2=gpiox,gpioy,gpioz,.....,gpiou,gpiov
      # where gpiox,gpioy,gpioz ... are NOT pin numbers on the connector, BUT location gpio numbered as in
      # https://www.raspberrypi-spy.co.uk/wp-content/uploads/2012/06/Raspberry-Pi-GPIO-Layout-Model-B-Plus-rotated-2700x900.png
      ## Set pin to -1 to disable it
      # controllers.gpio.args=map=5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,2 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,3
      ## MCP configuration : GPIO and MCP can be used together. You can mix them.
      ## map=0x20,0x21 for 2 mcp23017 on i2c bus
      #controllers.gpio.args=map=0x20,0x21,5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,-1 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,-1
      # ------------ D3 - Steam Controllers ------------ #
      ## Enable steam controller service
      controllers.steam.enabled=0
      ## DB9 Controllers
      controllers.db9.enabled=0
      ## db9 arguments
      controllers.db9.args=map=1
      ## Gamecon controllers
      ## Enable gamecon controllers, for nes, snes, psx (0,1)
      controllers.gamecon.enabled=0
      ## gamecon_args
      controllers.xarcade.enabled=1
      system.language=en_US
      system.kblayout=us
      ## Set you local time
      system.timezone=Canada/Pacific
      updates.enabled=1
      # Update type : default to stable
      updates.type=stable
      ## use 'auto' : switches to CEA 4 HDMI if supported, else keep the current resolution
      ## (string)
      global.videomode=CEA 4 HDMI
      ## Shader set
      ## (none, retro, scanlines)
      global.shaderset=none
      global.integerscale=0
      global.shaders=
      global.ratio=auto
      global.smooth=1
      global.rewind=1
      global.autosave=0
      global.retroachievements=0
      global.retroachievements.hardcore=0
      global.inputdriver=auto
      ## Demo screensaver parameters
      ## Set the system list from which ES will run random games.
      ## Empty list or unexisting key means all available systems
      global.demo.systemlist=atari2600,atari5200,atari7800,fba_libretro,fds,gamegear,gba,lynx,mame,mastersystem,megadrive,neogeo,nes,ngpc,o2em,pcengine,sega32x,sg1000,snes
      ## Default demo game sessions last 90s. Change this value if you want shorter or longer sessions
      ;global.demo.duration=90
      ## Default game info screen duration lasts 6s. Change this value if you want shorter or longer info screens.
      ;global.demo.infoscreenduration=6
      ## Retroarch AI Translation service
      ## Comment out or set to 0 the following key if you don't want the AI service
      global.translate=1
      ## Set the source and the target languages.
      ## Allowed language list: EN, ES, FR, IT, DE, JP, NL, CS, DA, SV, HR, KO, ZH_CN, ZH_TW, CA, BG, BN, EU, AZ, AR, SQ,
      ##                        AF, EO, ET, TL, FI, GL, KA, EL, GU, HT, IW, HI, HU, IS, ID, GA, KN, LA, LV, LT, MK, MS,
      ##                        MT, NO, FA, PL, PT, RO, RU, SR, SK, SL, SW, TA, TE, TH, TR, UK, UR, VI, CY, YI
      ## Setting the translate.from key to a specified language may speed up or give more accurate results
      ## If translate.to key is commented, the default value is extracted from system.language or, if system.language is
      ## undefined, set to auto (=EN).
      global.translate.from=auto
      global.translate.to=auto
      ## zTranslate API Key
      ## go to https://ztranslate.net and create an account.
      ## validate your account, then log in and go to the settngs page
      ## Look for the API Key at the bottom of the page, then uncomment the following key and paste your API Key:
      ;global.translate.apikey=YOUR_API_KEY_HERE
      ## Other translation service
      ## If you want to use another translation service or a custom API call, use this key to
      ## specify the url to call. If the key is not empty, it is used instead of zTranslation's API Key
      ;global.translate.url=
      ## Arcade metasystem
      ## Activate the Arcade metasystem to group all games from piFBA, FBN (libretro), MAME and optionally Neogeo
      ## into a single "Arcade" system.
      ;global.arcade=1
      ## You may want to specify its position in the system list. (Default: 0)
      ## Negatives values may be used to tart from the end (-1 = last position)
      ;global.arcade.position=0
      ## Include NeoGeo or not (default: 1)
      ;global.arcade.includeneogeo=1
      ## Hide included system or leave them in the system list (default: 1)
      ;global.arcade.hideoriginals=1
      ## You can override the global configurations here
      ## Here is the snes example
      ;snes.videomode=CEA 4 HDMI
      snes.core=snes9x2010
      ;snes.ratio=16/9
      ;snes.smooth=0
      ;snes.rewind=1
      ;snes.autosave=0
      snes.emulator=libretro
      ;snes.integerscale=0
      ## If you do not want recalboxOS to generate the configuration for the emulator:
      ## Default cores for RPi3
      ## NeoGeo emulator
      neogeo.emulator=fba2x
      ## If you set libretro as neogeo.emulator, the line below sets the retroarch core (fbneo, mame2000)
      neogeo.core=fba2x
      n64.videomode=DMT 4 HDMI
      # n64.videomode=default
      ## Dreamcast emulator
      ## Like N64, such a CPU intensive emulator needs a small resolution
      ## Consider DMT 4 HDMI (640*480) or DMT 9 HDMI (800*600). If you have a black screen on dreamcast, try DMT 9 HDMI here
      dreamcast.videomode=DMT 4 HDMI
      ## Include or exclude a particular system from the demo screensaver
      ## You may change the global.demo.systemlist key or include/exclude every single system
      ;snes.demo.include=0
      ## Set the session duration for a particular system
      ;snes.demo.duration=90
      # ------------ J - NETPLAY PARAMETERS ----------- #
      ## All these values are handled by Recalbox itself
      global.netplay=1
      global.netplay.nickname=
      global.netplay.port=55435
      global.netplay.relay=
      global.netplay.systems=fba_libretro,mame,mastersystem,megadrive,neogeo,nes,pcengine,sega32x,sg1000,snes,supergrafx
      global.netplay.lobby=http://lobby.libretro.com/list/
      gba.core=mgba
      mame.core=mame2015
      nes.core=fceunext
      fds.flatfolder=0
      fds.sort=0
      amiga1200.flatfolder=0
      amiga1200.sort=0
      c64.flatfolder=0
      c64.sort=0
      gw.flatfolder=0
      gw.sort=0
      mame.flatfolder=0
      mame.sort=0
      apple2.flatfolder=0
      apple2.sort=0
      zxspectrum.flatfolder=0
      zxspectrum.sort=0
      favorites.sort=0
      global.quitpresstwice=0
      neogeo.flatfolder=1
      neogeo.sort=0
      neogeo.autosave=0
      ngp.autosave=0
      ngpc.autosave=0
      atari2600.flatfolder=0
      atari2600.sort=0
      fba_libretro.flatfolder=0
      fba_libretro.sort=0
      mame.emulator=libretro
      psx.flatfolder=0
      psx.sort=0
      snes.flatfolder=0
      snes.sort=0
      segacd.core=genesisplusgx
      segacd.emulator=libretro
      megadrive.flatfolder=0
      megadrive.sort=0
      nes.flatfolder=0
      nes.sort=0
      amstradcpc.flatfolder=0
      amstradcpc.sort=0
      atari800.core=atari800
      atari800.emulator=libretro
      atari800.ratio=squarepixel
      lynx.flatfolder=0
      lynx.sort=0
      atari800.flatfolder=0
      atari800.sort=0
      atari7800.flatfolder=0
      atari7800.sort=0
      atarist.flatfolder=0
      atarist.sort=0
      n64.flatfolder=0
      n64.sort=0
      colecovision.flatfolder=0
      colecovision.sort=0
        Zing Global moderator Translator @flux last edited by
        @flux Start a game that uses retroarch (SNES for example), press Hotkey + B to access the Retroarch menu, scroll through the options until you find the user options, change the language as you wish.
        flux 1 Reply Last reply Reply Quote 0
        • flux
          flux @Zing last edited by
          @Zing Ok, I found it. Thank you!
          mundt1974 1 Reply Last reply Reply Quote 1
          • mundt1974
            mundt1974 @flux last edited by
            @flux how did you find it in French? I can't find the user settting in french
              Zing Global moderator Translator @mundt1974 last edited by
              @mundt1974 If I am not wrong:
              Start any game that belongs to Retroarch (SNES for example), press Hotkey + B to access the Retroarch menu, press B to go to the main menu, go to "réglagles", "Utilisateur", "Langue", and change "Français" for whatever you want.
              • mundt1974
                mundt1974 @Zing last edited by
                @Zing Thank You, worked great.
