    Unsolved Recalbox keeps wiping itself.
    recalbox keeps wiping itself
    • x925
      x925 last edited by
      I have reinstalled recalbox several times. Each time, after a seemingly random number of power cycles, using either the web ui or the menu in the OS to do so, it starts up with a different UI, the share folder is for some reason in RAM, the config file that i can find with the web ui is completely blank. I do not understand what is going on, but it is getting frustrating, i initially thought it might be the hard drive, but changing that out for several others seems to cause the same issue.
      Optiplex 7010 usff
      i3-3240
      4GB Ram
      320GB Mechanical Hard drive
        Zing Global moderator Translator @x925 last edited by
        @x925 Usually this happens when the system is not shutting down correctly, are you shutting down correctly, through the menu?
