    Recalbox 6.1.1 wont boot, Glx missing on display
    recalbox 6.1.1 wont boot glx
    • fixgg
      fixgg last edited by
      I cant get recalbox 6.1.1 to boot on pc. The problems I'm seeing is...
      Xlib: extension "GLX" missing on display ":0".
      Error creating SDL window
      GLX is not supported
      Main Thread crashed
      I'm not sure what to do now. I saw in another forum post that 6.1.1 might not work right with the nivida graphics and they recommend trying 6.1.
      I don't know if that's the right step, or where to find the older version of recalbox like 6.1.
      Any help would be appreciated. Thanks
      The pc has mcp61pm-hm rev 2.2 mother board with 6.0 bios. Amd athlon 64 x2 dual core processors with integrated nivida graphics. I wiped the hard drive and have it booting internally, but have the same problem booting from usb.
      Zing 1 Reply Last reply Reply Quote 1
      • Alexander Tolstykh
        Alexander Tolstykh last edited by
        Same problem here
          Zing Global moderator Translator @fixgg last edited by
          @fixgg said in Recalbox 6.1.1 wont boot, Glx missing on display:
          Apparently this is an incompatibility with the NVidia video card, probably some driver is missing.
          Older versions of Recalbox are not available, only the latest version is available.
          The new version of Recalbox is coming, I recommend that you wait a while, and maybe the new version solves the problem.
