    Set static IP for recalbox 6.1.1
    static recalbox 6.1.1
    • Quardah
      Quardah last edited by
      Hi.
      Running on 6.1.1 i am having trouble setting a static IP for the recalbox. i want to set a static ip to eth0, as simple as that.
      I tried this : https://github.com/recalbox/recalbox-os/wiki/Manual-IP-settings-(EN)
      but after reboot the IP goes back to dhcp (i do remount as read/write)
      this still remains in /etc/network/interfaces :
      cat /etc/network/interfaces
      Configure Loopback
      auto lo
      iface lo inet loopbac
      auto eth0
      iface eth0 inet static
      allow-hotplug eth0
      address 192.168.1.5
      network 192.168.1.0
      netmask 255.255.255.0
      gateway 192.168.1.1
      broadcast 192.168.1.255
      i tried connmanctl but there is no such command installed
      connmanctl services
      -sh: connmanctl: command not found
      i don't know what to try next.
      thank you for updating the doc at the same time if you lay out the solution here 🙂 thanks.
        Zing Global moderator Translator @Quardah last edited by
        @Quardah If I'm not mistaken, since version 6.1.1, it is possible to edit the ip manually in the recalbox.conf file:
        ## Wifi - static IP
        ## if you want a static IP address, you must set all 3 values (ip, gateway, and netmask)
        ## if any value is missing or all lines are commented out, it will fall back to the
        ## default of DHCP
        wifi.ip =
        It is much easier now, the tutorial you are following is probably out of date.
        Se a minha resposta foi Ăștil, por favor, dĂȘ um voto positivo, clicando na seta para cima logo abaixo da resposta, ao lado de "citar".
        • ClimberBear
          ClimberBear last edited by
          I have the same issue, the command is not available
          # find . -name connmanctl
          # connmanctl services
          And I'm trying to set static IP for the ethernet port (not the wifi), so the paramater wifi.ip is not for me.
          • olivierdroid92
            Hi
            Just to undersand.
            Why you did not keep Recalbox with Dynamic IP.
            Then in your DHCP settings, your profide a fixed IP linked to MAC adress of your recalbox ?
