    The Two Things Recalbox NEEDS
    things needs
    • GeneralMilkshake
      GeneralMilkshake last edited by
      So, there have been two things that I've wanted for Recalbox. This is really for MAME. Those two things would be the ability to use analog sticks correctly, and to use the wiimote's ir sensor as a lightgun. If this is supported in 4.0 then good times are to be had.
        paradadf Staff last edited by
        I read the other day on Github that the developer (that made the wii controllers work on recalbox) does not read the blog. So I would suggest, as it is an enhacement, that you open an Github issue for that. Would be great to be able to play duckhunt again aswell!
        • digitaLumberjack
          @paypay are you talking about the analog sensibility ? or your analog do not work at all on mame ?
          • GeneralMilkshake
            Unfortunately, the analogs don't work at all, unless I enable analog-to-digital, which is NOT fun when playing a racing game.
            • korsan57
              korsan57 last edited by
              Is it possibel to add a fan control support controlled over the gpio pins. This would be a nice feature for the rpi 3
              101.4k
