    Trouble uploading PSX ROMs. Please help!
    trouble uploading roms please help
    • rick311
      rick311 last edited by
      So I have the PSX BIOS on my recalbox. There are games I can play from it. I have gone into the recalbox from my computer via the network and delete games, but I cannot get any games loaded back onto it.
      What format should I be using? I basically go into the shared folder, then the Roms folder, then the PSX folder, drag from my desktop into that folder, restart the recalbox, but it doesn't show up in the menu as a playable game.
      I'm using a Mac. Is that an issue? Or is the site I'm downloading from giving me the wrong file type? (they are .rar or .zip files. )
        @rick311
        psx not support zip/rar files, check readme.txt file in psx rom folder.
        ## RECALBOX - SYSTEM PSX ##
        Put your playstation roms in this directory.
        Rom files must have a ".iso/.img/.pbp/.cue/.ccd/.cbn/.m3u/.chd" extension.
        .bin files need a .cue file to be started.
        These cores needs 3 new BIOS (names are case sensitive) :
        scph5500.bin - 8dd7d5296a650fac7319bce665a6a53c
        scph5501.bin - 490f666e1afb15b7362b406ed1cea246
        scph5502.bin - 32736f17079d0b2b7024407c39bd3050
