    Recalbox 6.1.1-DragonBlaze (Root Login Does Not Work)
    recalbox root login does
    2516
    • Smoothy13
      Smoothy13 last edited by
      It took about 5 minutes to put the Raspberry together, install the OS and load up the system. My problem is, nothing has been changed since getting it setup 5 minutes ago. But, for the life of me. The login: root password: recalboxroot is not recognized. It doesn't recognize the credentials in putty, windows. Has it changed? Am I missing something so simple?
        OyyoDams Staff @Smoothy13 last edited by
        @Smoothy13 reset putty (remove old ssh keys)
        Smoothy13 3 Replies Last reply Reply Quote 0
        • Smoothy13
          Smoothy13 @OyyoDams last edited by
          @OyyoDams still access denied. Even tried to reach the share \recalbox Asks for login, use login: root password: recalboxroot (username or password is incorrect)
          • Smoothy13
            @OyyoDams I'm using the image that is posted on the site...for pi 3b+
            • Smoothy13
              @OyyoDams I started over. Downloaded the image from the site, got it installed on the raspberry. Connected to my wireless, nothing else has been done. It is on my network. but still am unable to connect to it through Putty or \recalbox. Something wrong with the credentials that are part of the image? Something so simple is turning into a process.
                @Smoothy13 nothing to do with Recalbox, your issue is Putty related. Please clear your credentials cache on Putty.
                Smoothy13 1 Reply Last reply Reply Quote 0
                • Smoothy13
                  @OyyoDams cool, so I can connect through Putty, web address, but still unable to access it through Windows Explorer. Any ideas on that? 🙂
