    Wifi não Funciona Recalbox 6.1.1
    Recalbox geral
    wifi não funciona recalbox 6.1.1
    414
    • rogerdigital
      rogerdigital last edited by
      Ola galera estou usando o recalbox em um pc core 2 duo com 2 de ram, não consigo conectar no wifi, vi uns tutorial ensinando a trocar a região do wifi no recalbox.config mas na hora de salvar da acesso negado, alguem ja passou por isso, outro caso pode ser que a placa não está com o driver eu realizei alguns comandos e segue abaixo, obrigado
      Versão do Recalbox (Linux RECALBOX 4.15.16 #1 SMP Wed Nov 13 13:10:59 CET 2019 x86_64 GNU/Linux)
      lspci
      00:00.0 Host bridge: Intel Corporation 82945G/GZ/P/PL Memory Controller Hub (rev 02)
      00:01.0 PCI bridge: Intel Corporation 82945G/GZ/P/PL PCI Express Root Port (rev 02)
      00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
      00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
      00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 01)
      00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
      00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
      00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
      00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01)
      00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
      00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
      00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
      00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01)
      00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
      01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV710/M92 [Mobility Radeon HD 4530/4570/545v]
      01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] RV710/730 HDMI Audio [Radeon HD 4000 series]
      03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 01)
      04:00.0 Network controller: Qualcomm Atheros AR5416 Wireless Network Adapter [AR5008 802.11(a)bgn] (rev 01) Essa é a placa
      Com o ifconfig a placa não é listada
      ifconfig
      eth0 Link encap:Ethernet HWaddr 00:1F:D0:FF:79:17
      inet addr:192.168.11.2 Bcast:192.168.11.255 Mask:255.255.255.0
      UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
      RX packets:6579 errors:0 dropped:0 overruns:0 frame:0
      TX packets:4089 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:713217 (696.5 KiB) TX bytes:929125 (907.3 KiB)
      lo Link encap:Local Loopback
      inet addr:127.0.0.1 Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING MTU:65536 Metric:1
      RX packets:64 errors:0 dropped:0 overruns:0 frame:0
      TX packets:64 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:4736 (4.6 KiB) TX bytes:4736 (4.6 KiB)
      No arquivo interfaces está assim e não deixa alterar fala que é arquivo de sistema somente leitura
      Configure Loopback
      auto lo
      iface lo inet loopback
      allow-hotplug wlan0
      ifconfig up wlan0
      ifconfig: bad address 'wlan0'
        Zing Global moderator Translator @rogerdigital last edited by
        @rogerdigital Não entendo a parte técnica a este nível, então não consigo entender o log, mas como você afirma que está dando acesso negado, isso indica que você não está entrando com acesso ROOT antes de iniciar as alterações:
        https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN)
        E, ao que sei, antes de poder editar estes tipos de arquivo, você deve remontar o sistema de arquivos como rw. Então, tente estes comandos:
        mount -o remount,rw /
        Dê uma pesquisada melhor e vai encontrar vários tópicos a respeito do acesso root e de remontar como rw.
        Ainda sim, não descarto a possibilidade de incompatibilidade da placa de wifi, mas é meio incomum, a maioria dos problemas de incompatibilidade é com as placas de vídeo, você tem certeza que não há um botão físico para ativar a wifi? Já vi alguns usuários se batendo com problema na wifi em outras ocasiões, e era só apertar um botão, não sei se é o caso, mas não custa perguntar...
        rogerdigital 1 Reply Last reply Reply Quote 0
        • rogerdigital
          rogerdigital @Zing last edited by
          @Zing Fala ai man tudo bem, eu to ligado no lance do root eu fiz um curso ninja de linux mas não trabalho muito com ele ai vc meio que acaba esquecendo algumas coisas, eu não sei o que aconteceu mas eu consegui salvar depois não sei se era algum bug sei la, mas reiniciei e consegui.
          Agora não sei se vc manja de linux todas distribuições tem um comando para instalar e como não sei a versão que o recalbox foi desenvolvido não sei como instalar os driver nele, a placa ta presente mas falta driver pelo que vi, se conseguir me ajudar com isso, vou ativar as notificações nas configurações para poder ver vc ou outra pessoa me respondendo, isso deveria ser padrão ou ser questionado, por acaso entrei e vi que vc tinha respondido, desde já agradeço a força.
          paradadf rogerdigital 2 Replies Last reply Reply Quote 0
            paradadf Staff @rogerdigital last edited by
            @rogerdigital qual versão do recalbox você está usando?
            • rogerdigital
              rogerdigital @rogerdigital last edited by
              @rogerdigital ola amigo eu uso a 6.1.1 obrigado pela atenção.
                @rogerdigital tem certeza? Linux RECALBOX 4.15.16 #1 SMP Wed Nov 13 13:10:59 CET 2019 x86_64 GNU/Linux
                100.4k
