    Solved Problème sortie composite rpi3
    1771
    • vic1707
      vic1707 last edited by
      J'ai quelques soucis avec la sortie composite du rpi 3 (fil soudé sur la fiche PP24).
      J'ai testé avec deux pi 3, un neuf et celui nécessaire a ma gameboy (complètement désossé donc plus de ports...).
      L'installation de recalbox est toute neuve et voici les fichier
      conf.txt :
      # uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      disable_overscan=1
      # uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      # Sound output. Set to 0 or comment for autodetect, 1 for DVI, 2 to force HDMI.
      #hdmi_drive=1
      # Using /etc/modules is deprecated and no longer supported on 4.4 kernel
      # So manually enable audio
      dtparam=audio=on
      config_hdmi_boost=0
      # force hdmi while the tv can take time before sending the signal on the hdmi output
      # uncomment for composite PAL
      sdtv_mode=16
      sdtv_aspect=2
      hdmi_ignore_hotplug=0
      hdmi_force_hotplug=0
      # uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      # uncomment if you don't want the rainbow at startup
      disable_splash=1
      # default CEC name
      cec_osd_name=recalbox
      # Overclock
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=448
      avoid_safe_mode=1
      kernel=zImage
      # Raise the first security limit up to 70° instead of 60°
      temp_soft_limit=70
      et recalbox.conf :
      # System Variable
      ;system.power.switch=WITTYPI             # http://www.uugear.com/witty-pi-realtime-clock-power-management-for-raspberry-pi
      ;system.power.switch=PIN356PUSHRESET     # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
      ## fbcp FrameBuffer Copy Program
      ## For small TFT screen on GPIO and SPI
      ## See https://github.com/recalbox/recalbox-os/wiki/Utility---Use-of-fbcp-for-small-TFT-screen-%28EN%29 for details
      ## Needed for Waveshare 3.2" 3.5" TFT screen, 2.8" Adafruit screen
      ## See https://github.com/recalbox/recalbox-os/wiki/TFT-Screen-SPI-Bus-%28EN%29
      ## for support and configuration details needed by /boot/config.txt
      system.fbcp.enabled=0
      ## Splash screen duration
      ## 0: Video will be played for 20 seconds (default)
      ## -1: All the video will be played (it won't be stopped automatically)
      ## >0 : Time before the video will be stopped (in seconds)
      system.splash.length=0
      system.manager.enabled=1
      ## Currently, only version 2 is available
      system.manager.version=2
      ## Recalbox security
      # enforce security
      # samba password required
      # disable virtual gamepads
      system.security.enabled=0
      ## Recalbox API (REST)
      system.api.enabled=0
      ## Allow a specific resolution for ES only from the command : tvservice -m [MODE]
      ## Leave commented for the default usual behaviour
      ;system.es.videomode=CEA 4 HDMI
      ## EmulationStation
      ### menu style
      ### default -> default all options menu
      ### none -> no menu except the game search menu
      ### bartop -> less menu, only needed for bartops
      emulationstation.menu=default
      ### Select a system to show on boot (use rom directory name) (string)
      emulationstation.selectedsystem=favorites
      ### Show the gamelist of the first or selected system on boot (0,1)
      emulationstation.bootongamelist=0
      ### Disable system view. ES will boot and show ONLY the first or selected system (0,1)
      emulationstation.hidesystemview=0
      ### Pa**e Gamelists only. Show only games listed in gamelist.xml files (0,1)
      emulationstation.gamelistonly=0
      ### Force basicgameList view to be displayed, even if your game systems are scraped (0,1)
      emulationstation.forcebasicgamelistview=0
      ## Videosnaps
      ### Delay before videosnaps start, in millisecond. Default: 2s
      ;emulationstation.videosnaps.delay=2000
      ### Video loop times. 0 = no video. 1 or more = the video loops x times before fading out
      ;emulationstation.videosnaps.loop=1
      ## Scrapers
      ### ScreenScraper.fr
      ### Force media region - if not defined, region is taken from system.language. Default: us
      ;scraper.screenscraper.region=eu
      ### Force text language - if not defined, region is taken from system.language. Default: en
      ;scraper.screenscraper.language=fr
      ### Choose the media to download among:
      ### screenshot: game screenshot
      ### title     : game title screenshot
      ### box2d     : Front case
      ### box3d     : 3D rendered case
      ### mixv1     : Recalbox special mix image V1 (default)
      ### mixv2     : Recalbox special mix image V2
      ;scraper.screenscraper.media=mixv1
      ### ScreenScraper account
      ;scraper.screenscraper.user=
      ;scraper.screenscraper.password=
      ## Emulator special keys
      kodi.enabled=1
      ## Start kodi at launch (0,1)
      kodi.atstartup=0
      kodi.xbutton=1
      ## Allow a specific resolution for Kodi only from the command : tvservice -m [MODE]
      ## By default is using the default resolution of your screen
      kodi.videomode=default
      ;kodi.network.waittime=10
      ## Hyperion
      ## Hyperion allows you to use an ambilight like led system on your recalbox
      ## Use hypercon to create your configuration file, and copy it in /recalbox/share/system/configs/hyperion/hyperion.config.json
      hyperion.enabled=0
      ## Set system hostname
      system.hostname=RECALBOX
      ## Activate wifi (0,1)
      wifi.enabled=0
      ## Set wifi region
      ## More info here: https://github.com/recalbox/recalbox-os/wiki/Wifi-country-code-(EN)
      wifi.region=US
      ## Wifi SSID (string)
      ;wifi.ssid=new ssid
      ## Wifi KEY (string)
      ## after rebooting the recalbox, the "new key" is replace by a hidden value "enc:xxxxx"
      ## you can edit the "enc:xxxxx" value to replace by a clear value, it will be updated again at the following reboot
      ;wifi.key=new key
      ## Wifi - static IP
      ## if you want a static IP address, you must set all 3 values (ip, gateway, and netmask)
      ## if any value is missing or all lines are commented out, it will fall back to the
      ## default of DHCP
      ;wifi.ip=manual ip address
      ;wifi.gateway=new gateway
      ;wifi.netmask=new netmask
      # secondary wifi (not configurable via the user interface)
      ;wifi2.ssid=new ssid
      ;wifi2.key=new key
      # third wifi (not configurable via the user interface)
      ;wifi3.ssid=new ssid
      ;wifi3.key=new key
      ## Samba share
      system.samba.enabled=1
      ### Virtual Gamepads
      ### SSH
      system.ssh.enabled=1
      audio.device=auto
      ## Set system volume (0..100)
      audio.volume=90
      audio.bgmusic=1
      # Enable ERTM
      controllers.bluetooth.ertm=0
      controllers.ps3.enabled=1
      ## Choose a driver between bluez, official and shanwan
      ## bluez -> bluez 5 + kernel drivers, support official and shanwan sisaxis
      ## official -> sixad drivers, support official and gasia sisaxis
      ## shanwan -> shanwan drivers, support official and shanwan sisaxis
      controllers.ps3.driver=bluez
      # ------------ D2 - GPIO Controllers ------------ #
      ## GPIO Controllers
      controllers.gpio.enabled=0
      controllers.gpio.args=map=1,2
      ## Custom mk_gpio arguments,
      ## map=5 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk  for one controller,
      ## map=5 gpio1=pin1,pin2,pin3,.....,pin12,pin13
      ## map=5,6 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk gpio2=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk for 2 (map=5,map=5,6)
      ## map=5,6 gpio1=gpiox,gpioy,gpioz,.....,gpiou,gpiov gpio2=gpiox,gpioy,gpioz,.....,gpiou,gpiov
      # where gpiox,gpioy,gpioz ... are NOT pin numbers on the connector, BUT location gpio numbered as in
      # https://www.raspberrypi-spy.co.uk/wp-content/uploads/2012/06/Raspberry-Pi-GPIO-Layout-Model-B-Plus-rotated-2700x900.png
      ## Set pin to -1 to disable it
      # controllers.gpio.args=map=5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,2 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,3
      ## MCP configuration : GPIO and MCP can be used together. You can mix them.
      ## map=0x20,0x21 for 2 mcp23017 on i2c bus
      #controllers.gpio.args=map=0x20,0x21,5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,-1 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,-1
      # ------------ D3 - Steam Controllers ------------ #
      ## Enable steam controller service
      controllers.steam.enabled=0
      ## DB9 Controllers
      controllers.db9.enabled=0
      ## db9 arguments
      controllers.db9.args=map=1
      ## Gamecon controllers
      ## Enable gamecon controllers, for nes, snes, psx (0,1)
      controllers.gamecon.enabled=0
      ## gamecon_args
      controllers.xarcade.enabled=1
      system.language=en_US
      ;system.kblayout=us
      ## Set you local time
      ;system.timezone=Europe/Paris
      updates.enabled=1
      # Update type : default to stable
      updates.type=stable
      ## use 'auto' : switches to CEA 4 HDMI if supported, else keep the current resolution
      ## (string)
      global.videomode=default
      ## Shader set
      ## (none, retro, scanlines)
      global.shaderset=none
      global.integerscale=0
      global.shaders=
      global.ratio=auto
      global.smooth=1
      global.rewind=1
      global.autosave=0
      global.retroachievements=0
      global.retroachievements.hardcore=0
      global.inputdriver=auto
      ## Demo screensaver parameters
      ## Set the system list from which ES will run random games.
      ## Empty list or unexisting key means all available systems
      global.demo.systemlist=3do,amigacd32,atari2600,atari5200,atari7800,daphne,fba_libretro,fds,gamegear,gba,lynx,mame,mastersystem,megadrive,neogeo,nes,ngpc,pcengine,sega32x,sg1000,snes
      ## Default demo game sessions last 90s. Change this value if you want shorter or longer sessions
      ;global.demo.duration=90
      ## Default game info screen duration lasts 6s. Change this value if you want shorter or longer info screens.
      ;global.demo.infoscreenduration=6
      ## Retroarch AI Translation service
      ## Comment out or set to 0 the following key if you don't want the AI service
      global.translate=1
      ## Set the source and the target languages.
      ## Allowed language list: EN, ES, FR, IT, DE, JP, NL, CS, DA, SV, HR, KO, ZH_CN, ZH_TW, CA, BG, BN, EU, AZ, AR, SQ,
      ##                        AF, EO, ET, TL, FI, GL, KA, EL, GU, HT, IW, HI, HU, IS, ID, GA, KN, LA, LV, LT, MK, MS,
      ##                        MT, NO, FA, PL, PT, RO, RU, SR, SK, SL, SW, TA, TE, TH, TR, UK, UR, VI, CY, YI
      ## Setting the translate.from key to a specified language may speed up or give more accurate results
      ## If translate.to key is commented, the default value is extracted from system.language or, if system.language is
      ## undefined, set to auto (=EN).
      global.translate.from=auto
      global.translate.to=auto
      ## zTranslate API Key
      ## go to https://ztranslate.net and create an account.
      ## validate your account, then log in and go to the settngs page
      ## Look for the API Key at the bottom of the page, then uncomment the following key and paste your API Key:
      ;global.translate.apikey=YOUR_API_KEY_HERE
      ## Other translation service
      ## If you want to use another translation service or a custom API call, use this key to
      ## specify the url to call. If the key is not empty, it is used instead of zTranslation's API Key
      ;global.translate.url=
      ## Arcade metasystem
      ## Activate the Arcade metasystem to group all games from piFBA, FBN (libretro), MAME and optionally Neogeo
      ## into a single "Arcade" system.
      ;global.arcade=1
      ## You may want to specify its position in the system list. (Default: 0)
      ## Negatives values may be used to tart from the end (-1 = last position)
      ;global.arcade.position=0
      ## Include NeoGeo or not (default: 1)
      ;global.arcade.includeneogeo=1
      ## Hide included system or leave them in the system list (default: 1)
      ;global.arcade.hideoriginals=1
      ## You can override the global configurations here
      ## Here is the snes example
      ;snes.videomode=CEA 4 HDMI
      ;snes.core=snes9x2010
      ;snes.ratio=16/9
      ;snes.smooth=0
      ;snes.rewind=1
      ;snes.autosave=0
      ;snes.emulator=libretro
      ;snes.integerscale=0
      ## If you do not want recalboxOS to generate the configuration for the emulator:
      ## Default cores for RPi3
      ## NeoGeo emulator
      neogeo.emulator=libretro
      ## If you set libretro as neogeo.emulator, the line below sets the retroarch core (fbneo, mame2000)
      neogeo.core=fbneo
      # n64.videomode=DMT 4 HDMI
      n64.videomode=default
      ## Dreamcast emulator
      ## Like N64, such a CPU intensive emulator needs a small resolution
      ## Consider DMT 4 HDMI (640*480) or DMT 9 HDMI (800*600). If you have a black screen on dreamcast, try DMT 9 HDMI here
      dreamcast.videomode=DMT 4 HDMI
      ## Include or exclude a particular system from the demo screensaver
      ## You may change the global.demo.systemlist key or include/exclude every single system
      ;snes.demo.include=0
      ## Set the session duration for a particular system
      ;snes.demo.duration=90
      # ------------ J - NETPLAY PARAMETERS ----------- #
      ## All these values are handled by Recalbox itself
      global.netplay=1
      global.netplay.nickname=
      global.netplay.port=55435
      global.netplay.relay=
      global.netplay.systems=fba_libretro,mame,mastersystem,megadrive,neogeo,nes,pcengine,sega32x,sg1000,snes,supergrafx
      global.netplay.lobby=http://lobby.libretro.com/list/
      J'espere ne pas avoir raté quoi que ce soit de trop evident...
      Le fichier conf.txt a été modifié via le tuto et une autre fois via ce lien qui disait avoir la solution...
      Merci d'avance
        Bonjour @vic1707
        peut être que @ian57 aura une idée
        • ian57
          ian57 Staff last edited by
          @vic1707 pour le composite j'avais ça :
          sdtv_mode=2
          #sdtv_mode=0    Normal NTSC
          #sdtv_mode=1    Japanese version of NTSC – no pedestal
          #sdtv_mode=2    Normal PAL
          #sdtv_mode=3    Brazilian version of PAL – 525/60 rather than 625/50, different subcarrier
          #better sound
          audio_pwm_mode=2
          sdtv_aspect=1  #4:3
          #sdtv_aspect=1  4:3
          #sdtv_aspect=2  14:9
          #sdtv_aspect=3  16:9
          #force tv mode
          hdmi_group=1
          hdmi_mode=8 #240p  60Hz
          #hdmi_mode=17 #576p 60Hz
          #to get a scaled image
          overscan_scale=1
          # to tune overscan
          overscan_left=0
          overscan_right=10
          overscan_top=4
          overscan_bottom=4
          #force composite
          hdmi_ignore_hotplug=1
          si tout est lent cela vient de mode = 2 qui améliore le son mais avec possibilité de ralentissement, surtout sur Pi zero et en composite du coup on passe en
          #better sound
          audio_pwm_mode=0
          pour recalboc.conf, je drirait qu'il faut passer en default video global comme tu l'as fait
          si ES est trop petit fixer un mode entrelacé pour es
          ## (string)
          • vic1707
            @ian57 Merci pour ta réponse, malheureusement toujours rien.
            Mon recalbox.conf contient bien la ligne avec default (ligne 264).
            pour le config.txt j'ai tenté ça :
            #hdmi_safe=1
            #disable_overscan=1
            #hdmi_group=1
            #hdmi_mode=1
            #hdmi_drive=1
            dtparam=audio=on
            config_hdmi_boost=0
            sdtv_mode=2
            audio_pwm_mode=2
            #dtoverlay=lirc-rpi
            boot_delay=3
            disable_splash=1
            # default CEC name
            # Overclock
            gpu_mem_256=128
            gpu_mem_512=256
            gpu_mem_1024=448
            avoid_safe_mode=1
            kernel=zImage
            temp_soft_limit=70
            • ian57
              tu as bien vérifier que ton jack est câblé correctement? cf https://recalbox.gitbook.io/tutorials/v/francais/iii-video/crt/connectez-votre-recalbox-a-un-crt-avec-composite
              • vic1707
                vic1707 last edited by vic1707
                Hello,
                Désolé de la réponse tardive je cherchais un cable pour tester, manque de bol le seul qui pouvais marcher était niqué j'ai du le refaire en soudant donc image degeu.
                Bref long story short, ça "marche" sur ma tv : image degeu
                J'ai donc une image floue (sans doute a cause des soudure pourries) en noir et blanc.
                La config pour y arriver est celle de mon dernier message.
                Le hic c'est que je cherche à avoir l'image sur un écran 3.5" 4/3 (#gameboy) qui d'après la boite supporte le NTSC et PAL
                vic1707 1 Reply Last reply Reply Quote 0
                • vic1707
                  vic1707 @vic1707 last edited by
                  Le tout est aussi terriblement lent (boot animation)
                  Que dois-je modifier pour avoir du coup un truc plus fluide qui marchera sur l'ecran 4/3 ?
                  Merci d'avance @ian57
                  • ian57
                    ian57 Staff @vic1707 last edited by
                    @vic1707 a mon avis change pour
                    #better sound
                    audio_pwm_mode=0
                    c'est un bug connu
                    • vic1707
                      vic1707 @ian57 last edited by
                      @ian57 Merci et concernant le noir et blanc?
                      • ian57
                        @ian57 said in Problème sortie composite rpi3:
                        sdtv_mode=2
                        essaie de changer le mode
                        • vic1707
                          @ian57 Super ça a marché ! fluide, couleur tout vas bien, j'esspere que ça sera pareil sur l'ecran de 3.5" quand je les recevrait
