    Old Legacy PC and Recalbox
    Emulator Arcade/PC/Console
    old legacy recalbox
    3689
    • comland
      comland last edited by comland
      I post this again, because i didn't got any answer
      Hello all!!
      I tried to run Recalbox 6.1 on an Core 2 Duo PC and it works like a charm!!
      Then I tried to run it on a Pentium 4 3.00 GHz (Prescott) and it wouldn't finish booting... It stops somewhere before the GUI... I tried on like 6 different PCs of that era, same thing on all of them. I guess it has something to do with the old hardware and the linux core...
      Is there an older version of recalbox that i can use on that kind of old PCs? I'm trying to give these PCs a new purpose...
      Thank you in advance!!!
      George
      comland 1 Reply Last reply Reply Quote 0
      • comland
        comland @comland last edited by
        Anybody????
        Is there maybe an old version of recalbox that i can use??
          Scavy Global moderator @comland last edited by
          Hi @comland
          Here is the stuff compatibility : stuff
          and here the PC compatibillity : PC Comp
          Check it, check the GPU compatibility. Could you describe your configuration ?
          comland 1 Reply Last reply Reply Quote 1
          • comland
            comland @Scavy last edited by
            @Scavy
            Hello Scavy!! Thanks for your reply!
            My PC is a Pentium 4 3GHz prescott (a 478 socket CPU)
            It's quite old, i know...
            The VGA card is a Geforce MX 400 with 64MB ram (AGP)
            The PC compatibility is for way newer PCs, at least 4-5 generations ahead....
            I have successfully installed recalbox on a Core2 Duo CPU (775 socket) with a 5500 Geforce VGA card (PCIEX)
            It works like a charm, I was just wondering if i can use it on older computers
            I have already a build of my own with windows XP which works with even Pentium III machines, but i wanted something from linux... I tried Puppy arcade, but it needs keyboard and mouse. I wanted something more automated, like recalbox. It's an amazing piece of work!!!
            Can you help me maybe with another older version of recal box with less hardware requirements or maybe another arcade operating system build?
            Thank you so much in advance!!
              @comland we're asking the master of recalbox on PC build ^^ @strodown
              • comland
                @Scavy I hope he can help us!! Please @strodown , enlighten us!! 😊 😳
                strodown 1 Reply Last reply Reply Quote 0
                • strodown
                  strodown @comland last edited by
                  @comland
                  Hello
                  I think it's a problem with your graphics card (nvidia).
                  an error in the official driver installation script may be the cause.
                  I advise you to go to our discord server for better support of your concerns,
                  Thank you
                  Strodown
                  Recalbox X86_64 :
                  X-Arcade
                  Lightgun Mayflash Dolphin-bar
                  • comland
                    comland @strodown last edited by
                    @strodown @Scavy Thank you very much my friends! I will look into it!!
                    • Referenced by  oni oni
