    Y axis inverted in Switch bluetooth controller
    GamePad/GPIO/USB encoder
    axis inverted switch bluetooth
    5297
    • xphere
      xphere last edited by
      Hi,
      I have succesfully paired a nintendo switch pro-controller (chinese clone from aliexpress), and everything seems to work fine, except the vertical axis (Y) of the analog controller. On all emulators when I press up, it goes down, and vice-versa.
      Do you know how I can fix this?
      Thanks a lot!
      The controller tha tI am talking about can be found here.
        OyyoDams Staff @xphere last edited by
        @xphere hi,
        Just remap your controller in Recalbox options.
        • xphere
          Thanks OyyoDams!
          That is the first thing I tried, but no matter how I configure the joystick, the Y axis is always inverted.
          I have tried in the configuration to press up the joystick when is asked to press "joy up" and still appears inverted. I have tried to press down the joystick when is asked to press "joy up", but again, the Y axis is inverted.
          Maybe I should look on some config file, where I can see the exact mapping of the controller?
            @xphere can you make a support archive ?
            xphere 1 Reply Last reply Reply Quote 1
            • xphere
              Sure! I will do!
              Btw, I have seen that if I open a game and enter into retroarch config, I can swap direction of Y axis and then works fine, but since config is not stored, that configuration is lost when I switch to another game.
              • xphere
                xphere @OyyoDams last edited by
                @OyyoDams What do you mean by "support archive"? do you mean to open an issue in GitLab?
                  Scavy Global moderator @xphere last edited by
                  @xphere
                  Via recalbox-manager
                  Open your internet browser:
                  On Windows http://recalbox/help or http://ip_recalbox /help
                  On Mac / Linux http://recalbox.local/help.
                  A link will be automatically uploaded and a link will be given to you.
                  Post the link in your current topic on the forum or in the issue you have opened.
                  • xphere
                    xphere @Scavy last edited by
                    @Scavy thanks a lot! I will do asap!!
                    • xphere
                      here you have the link! https://transfer.sh/7VbNO/recalbox-support-e50530f9-944d-8056-a8ee-1278dce1bf44.tar.gz
                      If you want, I can raise an issue too.
                      Scavy OyyoDams 2 Replies Last reply Reply Quote 0
                        @xphere @OyyoDams
                          @xphere please try the following. Edit es_input.cfg file, and replace:
                          	<inputConfig type="joystick" deviceName="Pro Controller" deviceGUID="050000007e0500000620000001000000" deviceNbAxes="4" deviceNbHats="1" deviceNbButtons="16">
                          		<input name="a" type="button" id="0" value="1" code="304" />
                          		<input name="b" type="button" id="2" value="1" code="306" />
                          		<input name="down" type="hat" id="0" value="4" code="16" />
                          		<input name="hotkey" type="button" id="12" value="1" code="316" />
                          		<input name="joystick1left" type="axis" id="0" value="-1" code="0" />
                          		<input name="joystick1up" type="axis" id="1" value="1" code="1" />
                          		<input name="joystick2left" type="axis" id="2" value="-1" code="3" />
                          		<input name="joystick2up" type="axis" id="3" value="1" code="4" />
                          		<input name="l2" type="button" id="6" value="1" code="310" />
                          		<input name="l3" type="button" id="10" value="1" code="314" />
                          		<input name="left" type="hat" id="0" value="8" code="16" />
                          		<input name="pagedown" type="button" id="5" value="1" code="309" />
                          		<input name="pageup" type="button" id="4" value="1" code="308" />
                          		<input name="r2" type="button" id="7" value="1" code="311" />
                          		<input name="r3" type="button" id="11" value="1" code="315" />
                          		<input name="right" type="hat" id="0" value="2" code="16" />
                          		<input name="select" type="button" id="8" value="1" code="312" />
                          		<input name="start" type="button" id="9" value="1" code="313" />
                          		<input name="up" type="hat" id="0" value="1" code="16" />
                          		<input name="x" type="button" id="1" value="1" code="305" />
                          		<input name="y" type="button" id="3" value="1" code="307" />
                          	</inputConfig>
                          by
                          		<input name="joystick1up" type="axis" id="1" value="-1" code="1" />
                          		<input name="joystick2up" type="axis" id="3" value="-1" code="4" />
                          	</inputConfig>
                          Then try again with a game
                          • xphere
                            xphere last edited by xphere
                            @OyyoDams said in Y axis inverted in Switch bluetooth controller:
                            Thanks for the reply. I've done the modification, but the issue persist. I've done the following:
                            1- Access via sftp and modify the file
                            2- Reboot recalbox
                            3- Tried the emulators: snes, genesis, neo-geo and Doom. All still have the Y axis inverted.
                            It's strange, because in the config file the Y axis seems to be inverted in the new cnofig file, so, should work...
                            Any other idea?
                            EDIT: I have tried modifying another line, just for debugging. So I've replaced, for the same controller:
                            By this one:
                            	<input name="joystick1left" type="axis" id="0" value="1" code="0" />
                            But also, no effect, so the X axis has not been inverted either... maybe this is not the right controller config that should be modifying?
                              @Bkg2k ?
                              • xphere
                                fyi... this issue seems to be related to: https://forum.recalbox.com/topic/3265/wii-classic-controller-pro-axis-reversed
