    Logitech F310 L2 and R2 Button configuration problems
    GamePad/GPIO/USB encoder
    logitech f310 button
    • havic626
      havic626 last edited by
      When i setup the button configurations on my Logitech F310, the L2 and R2 button want to change to a axis button.  I tried to switch to direct input on the back of the controller but then it is no longer recognized and Recalbox crashes.  Is there a fix for this?
      • lmerckx
        lmerckx last edited by
        Hello, I had the same problem with the Logitech F710, but it is not a problem to map these buttons as axis. I did it and all games using these buttons work perfectly ! Kind regards.
        Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
        Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
        • havic626
          I appreciate the response.  I do want to play ps1 games so that would throw it off.  I had the same problem trying to use retropi.  I read elsewhere that putting it in direct mode on the controller would fix it but when I do that recalbox does not detect the controller.
