    GPIO activate on startup
    GamePad/GPIO/USB encoder
    gpio activate startup
    1511
    • naitreia
      naitreia last edited by
      Hi,
      is it possible to activate on startup a GPIO-Pin to activate an Optokoppler?
      Cheers
      • naitreia
        Hi,
        noone who can help me?
        i tryed it with this as script but it's not working:
        case "$1" in
        start)
        echo „18“ > export
        echo "out" > gpio18/direction
        echo "1" > gpio18/value
        stop)
        echo "0" > gpio18/value
        restart|reload)
        Add your restart / reload code here!
        esac
        exit $?
        Cheers
        • naitreia
          Hi,
          really no one who can help here?
          I only want to have for example GPIO18 as output when recalbox is starting to controle a optocoupler.
          Cheers
          • ian57
            @naitreia you can create the custom.sh file in /recalbox/share/system/ like this :
            #!/bin/sh
            # Start optocoupler
            # Support for optocoupler
            # GPIO numbers should be from this list
            # 0, 1, 4, 7, 8, 9, 10, 11, 14, 15, 17, 18, 21, 22, 23, 24, 25
            # Note that the GPIO numbers that you program here refer to the pins
            # of the BCM2835 and *not* the numbers on the pin header.
            # So, if you want to activate GPIO7 on the header you should be
            # using GPIO4 in this script. Likewise if you want to activate GPIO0
            # on the header you should be using GPIO17 here.
            start() {
                    echo -n "Starting opto: "
                    # Set up GPIO 18 and set to output
                    echo "18" > /sys/class/gpio/export
                    echo "out" > /sys/class/gpio/gpio18/direction
                    # Write output
                    echo "1" > /sys/class/gpio/gpio18/value
                    echo "OK"
            stop() {
                    echo -n "Stopping opto: "
                    # Write output
                    echo "0" > /sys/class/gpio/gpio18/value
                    # Clean up
                    echo "18" > /sys/class/gpio/unexport
                    echo "OK"
            case "$1" in
              start)
                    start
              stop)
                    stop
              restart|reload)
                    stop
                    start
                    echo "Usage: $0 {start|stop|restart}"
                    exit 1
            esac
            exit $?
            don't forget
            chmod 755 custom.sh
            You can try to use it with
            /etc/init.d/S99custom start
            you should get
            # /etc/init.d/S99custom start
            Starting opto: OK
            • naitreia
              Thx for this i will try it today!
              • ian57
                ian57 Staff @naitreia last edited by
                @naitreia I corrected 2 errors in the scripts above, please be sure to copy the code after this post 🙂
                101.4k
