    4 Bluetooth Controllers at the same Time?
    GamePad/GPIO/USB encoder
    bluetooth same
    • Domi1l
      Domi1l last edited by
      Hello,
      does anybody have 4 Controllers on his Raspberry pi connectet with Bluetooth? First i tried with the internal Bluetooth Chip. This worked quite well, but the controllers had an massiv input lag. I tried two several Bluetooth Dongles and all i can pair were 3 Controllers maximum. Does anybody of you guys paired 4 Controllers at the same time? I have a raspberry pi 3 with the latest Recalbox on it.
      Thank you guys. And sorry for my bad English ;-D
        Hello
        try this
        Pour les problèmes suivants merci d'effectuer ses vérifications :
        • plus de 2 manettes 8bitdo utilisés et autres
        • problème en jeu
          • assurez vous d'avoir le dernier firmware disponible : https://support.8bitdo.com/
          • utiliser le mode android uniquement.
          • Supprimer les manettes dans le menu Emulationstation > options manettes > oublier les manettes.
          • Editer recalbox.conf avec winscp et notepad++ ou le partage réseau NE PAS UTILISER LE MANAGER !
            • active l'option ERTM=0 ->1
              #Enable ERTM
              controllers.bluetooth.ertm=1
          • Rebooter recalbox
          • Démarrer le mode android, réaliser de nouveau l'appareillage.
          • Tester
        • Domi1l
          @acris
          somehow i cant connect any of my Bluetooth controllers after changing that. I don't have controllers from 8bitdo. The Controllers are PS3 Controllers (Shanwan) i forget to say that in my thread.
