    Can't boot after flashing to SD card
    cant boot installing card
    • OMGdaDPS
      OMGdaDPS last edited by OMGdaDPS
      I downloaded the .img file from here, which is the correct one for my situation.
      So after flashing the img file to an SD card via the recommended etcher program, I insert it into my laptop's SD card slot and boot into it. After selecting the option to boot into RecalBox on the screen that pops up (with two options), I black screen appears with a blinking cursor, and does nothing after that.
      After having waited for a while to see if it was just being slow, I decided to reboot and select the "verbose" option at the boot screen. It shows the boot process, and all seems to go well up until a certain point, at which it starts saying this:
      mount: mounting LABEL=RECALBOX on /new_root failed: No such file or directory
      Waiting for the root device
      Then it just keeps repeating it over and over, and does nothing else.
      Here are some specs of the machine that I am trying to run this on:
      • HP EliteBook 840 G2
      • i5-5300U CPU
      • Intel HD Graphics 5500
      • 8 GB of DDR3 memory
      If there is any other info that I can provide, please let me know, I would be more than happy to give it!
      • lionsquall
        lionsquall last edited by
        @OMGdaDPS Can you try to flash the system on a hard drive?
        Installation on sd and usb stick is strongly discouraged on Pc.
        Please give us a return
        OMGdaDPS 1 Reply Last reply Reply Quote 0
        • OMGdaDPS
          Hey! Thank you for responding! How would I do that though? Is there a live image somewhere that I can download?
          • OMGdaDPS
            OMGdaDPS @lionsquall last edited by
            @lionsquall said in Can't boot after flashing to SD card:
            The reason I ask this is because there are literally only two ways to install according to the Github page in english. One is for the Pi, which doesn't apply to me, and the other is to flash the image to an SD card or USB stick (using win32diskimager) and booting into it (I guess, as it doesn't really say much)
            Here are the instructions I am referring to.
