    Hotkey HELP
    GamePad/GPIO/USB encoder
    hotkey help
    2847
    • Nero
      Nero last edited by
      Hi. So I recently loaded up Recalbox and configured my USB controllers (arcade button kit). A B X Y L R Start and Select all working for both players. I also set up a dedicated Hotkey button, but whenever I try to use any of the Hotkey Combos it never works with my dedicated button and only works on the Select buttons, how do i fix this? Please and Thanks
        OyyoDams Staff @Nero last edited by
        @nero what is your controller ?
        • Nero
          Nero last edited by Nero
          @OyyoDams It's a USB encoder from a kit that came with arcade buttons and joysticks and then plugs into the Pi through USB.
          https://www.ebay.com.au/itm/Arcade-DIY-Kit-Mame-Raspberry-Pi-Games-2-Arcade-joystick-20-Chrome-LED-Buttons/132777941951?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
            @nero ok. Your "dedicated" button is mapped to which button ?
            • Nero
              @oyyodams I have it set up as a seperate button in the top-centre of my control panel. It's plugged into K8 on this diagram and in the controller configuration screen it says it's mapped to "Button 7"
                @nero ok please try again:
                • setup the hotkey on this button
                • make a support archive and post the link here
                • zetof
                  zetof last edited by
                  Did you configured both players ?
                  I think you must configure only one player...
                  I think if you configure second player without hotkey, it will erase first player...
                  Nero 1 Reply Last reply Reply Quote 0
                  • Nero
                    Nero @zetof last edited by
                    @zetof The configuration menu won't let me setup without a hotkey so P2 hotkey is set to P2 Select
                      @nero no, you must NOT configure a hotkey to P2. Please bypass it.
                      • Nero
                        Nero @OyyoDams last edited by Nero
                        @oyyodams It won't let me bypass, it says input required, I can't skip it I pressed down on the P1 joystick and it allowed me to bypass it. I now only have hotkey setup for P1
                        • Nero
                          Nero last edited by
                          @OyyoDams So i now have it only configured for hotkey for P1 and not P2, it still only works with Select. I'm not entirely sure how to make a support archive but hopefully this is what you mean
                          https://www94.zippyshare.com/v/L67fglkV/file.html
                            @nero please make it via the web interface
                            • Nero
                              @oyyodams I pressed "Launch Script" in the "Support" tab and it says "Internal Server Error"
                                @nero in this case you can try by ssh, but please upload the archive file, not the script 🙂
                                • Nero
                                  @oyyodams I'm really sorry, I'm very new to this, and as such I simply don't know how to do that. If i connect via ssh, what do I type in to get the archive file. Sorry to seem ignorant I'm just very new to recalbox.
                                  • zetof
                                    Reconfigure only player 1 with your dedicated hotkey.
                                    Do not configure player 2.
                                    And it will work.
                                    100.7k
