    Big file transfer issue to recalbox using HTTP,SMB,SSH while TV streaming works fine
    big file transfer issue recalbox
    • A Former User
      A Former User last edited by
      Hello,
      I have an issue with my Recalbox.
      I use latest 6.1.1 with a raspberry pi 3+ connected using ethernet 1Gb/s (100 MB/s measured)
      Everything works well, games, kodi, streaming TV with HDHomerun, Plex, video playing ...etc...
      but when I need to transfer files either using ssh or samba using windows shareafter a few seconds the connection is lost.
      I tried using ssh this small script to ensure µsd card was not involved:
      while true
      do
      sync
      sleep 5
      done
      but it doesn't help (or I want to believe it so strong that it is better but the conneciton remains lost ...)
      µSD card is a class 10 and I have validated it works fine.
      As root partition was short, I have expanded it by one gigabyte, because it was close to be 100% full:
      mount
      /dev/root on / type ext4 (ro,relatime,data=ordered)
      devtmpfs on /dev type devtmpfs (rw,relatime,size=313804k,nr_inodes=78451,mode=755)
      proc on /proc type proc (rw,relatime)
      devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
      tmpfs on /dev/shm type tmpfs (rw,relatime,mode=777)
      tmpfs on /tmp type tmpfs (rw,relatime)
      tmpfs on /var type tmpfs (rw,relatime)
      tmpfs on /run type tmpfs (rw,relatime)
      sysfs on /sys type sysfs (rw,relatime)
      /dev/mmcblk0p1 on /boot type vfat (ro,relatime,fmask=0022,dmask=0022,codepage=437,iocha**et=ascii,shortname=mixed,errors=remount-ro)
      /dev/mmcblk0p3 on /recalbox/share type ext4 (rw,noatime,data=ordered)
      df -h
      Filesystem Size Used Available Use% Mounted on
      /dev/root 2.9G 1.9G 891.8M 68% /
      devtmpfs 306.4M 0 306.4M 0% /dev
      tmpfs 310.9M 0 310.9M 0% /dev/shm
      tmpfs 310.9M 0 310.9M 0% /tmp
      tmpfs 310.9M 4.7M 306.3M 2% /var
      tmpfs 310.9M 140.0K 310.8M 0% /run
      /dev/mmcblk0p1 63.0M 7.9M 55.1M 13% /boot
      /dev/mmcblk0p3 26.1G 23.8G 1.0G 96% /recalbox/share
      I checked dmesg and have no errors
      I checked /var/log/messages
      Jan 1 02:00:13 RECALBOX daemon.info init: Entering runlevel: 3
      Jan 1 02:00:14 RECALBOX daemon.info ntpd[790]: Listen normally on 5 eth0 10.0.1.60:123
      Jan 1 02:00:14 RECALBOX daemon.err ntpd[790]: bind(24) AF_INET6 fd00::ba27:ebff:fe7c:1173#123 flags 0x11 failed: Cannot assign requested address
      Jan 1 02:00:14 RECALBOX daemon.err ntpd[790]: unable to create socket on eth0 (6) for fd00::ba27:ebff:fe7c:1173#123
      Jan 1 02:00:14 RECALBOX daemon.info ntpd[790]: failed to init interface for address fd00::ba27:ebff:fe7c:1173
      Jan 1 02:00:14 RECALBOX daemon.err ntpd[790]: bind(24) AF_INET6 2001:7e8:c818:7500:ba27:ebff:fe7c:1173#123 flags 0x11 failed: Cannot assign requested address
      Jan 1 02:00:14 RECALBOX daemon.err ntpd[790]: unable to create socket on eth0 (7) for 2001:7e8:c818:7500:ba27:ebff:fe7c:1173#123
      Jan 1 02:00:14 RECALBOX daemon.info ntpd[790]: failed to init interface for address 2001:7e8:c818:7500:ba27:ebff:fe7c:1173
      Jan 1 02:00:14 RECALBOX daemon.info ntpd[790]: Listen normally on 8 eth0 [fe80::ba27:ebff:fe7c:1173%3]:123
      Jan 1 02:00:14 RECALBOX daemon.info avahi-daemon[797]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::ba27:ebff:fe7c:1173.
      Jan 1 02:00:14 RECALBOX daemon.info avahi-daemon[797]: Joining mDNS multicast group on interface eth0.IPv6 with address fd00::ba27:ebff:fe7c:1173.
      Jan 1 02:00:14 RECALBOX daemon.info avahi-daemon[797]: Registering new address record for fd00::ba27:ebff:fe7c:1173 on eth0..
      Jan 1 02:00:14 RECALBOX daemon.info avahi-daemon[797]: Withdrawing address record for fe80::ba27:ebff:fe7c:1173 on eth0.
      Jan 1 02:00:14 RECALBOX daemon.info avahi-daemon[797]: Service "recalbox" (/etc/avahi/services/ssh.service) successfully established.
      Jan 1 02:00:14 RECALBOX daemon.info avahi-daemon[797]: Service "recalbox" (/etc/avahi/services/sftp-ssh.service) successfully established.
      Jan 1 02:00:14 RECALBOX daemon.info avahi-daemon[797]: Registering new address record for 2001:7e8:c818:7500:ba27:ebff:fe7c:1173 on eth0.
      Jan 1 02:00:16 RECALBOX daemon.info ntpd[790]: Listen normally on 9 eth0 [fd00::ba27:ebff:fe7c:1173]:123
      Jan 1 02:00:16 RECALBOX daemon.info ntpd[790]: Listen normally on 10 eth0 [2001:7e8:c818:7500:ba27:ebff:fe7c:1173]:123
      Jan 1 02:00:16 RECALBOX daemon.info ntpd[790]: 2606:4700:f1::1 local addr fe80::ba27:ebff:fe7c:1173%3 -> 2001:7e8:c818:7500:ba27:ebff:fe7c:1173
      Feb 9 14:52:22 RECALBOX daemon.info ntpd[790]: receive: Unexpected origin timestamp 0x967932a5.1cceaebd does not match aorg 0000000000.00000000 from server@2606:4700:f1::1 xmt 0xe1ea8d16.822af09a
      Feb 9 14:52:31 RECALBOX authpriv.info dropbear[1080]: Child connection from 10.0.1.19:50295
      Feb 9 14:52:33 RECALBOX authpriv.notice dropbear[1080]: Pubkey auth succeeded for 'root' with key md5 9b:49:8e:a6:df:0b:23:b3:3e:6b:08:60:27:cb:8d:58 from 10.0.1.19:50295
      Feb 9 14:57:31 RECALBOX daemon.info ntpd[790]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized
      Feb 9 14:01:34 RECALBOX user.info kernel: [ 574.111310] ip_tables: (C) 2000-2006 Netfilter Core Team
      I have reconfigured ntp.conf the relaunched ntpd
      Feb 9 14:08:14 RECALBOX user.info kernel: [ 974.574068] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
      Feb 9 15:08:48 RECALBOX daemon.notice ntpd[790]: ntpd exiting on signal 15 (Terminated)
      Feb 9 15:08:48 RECALBOX daemon.info ntpd[790]: 194.42.98.91 local addr 10.0.1.60 -> <null>
      Feb 9 15:08:48 RECALBOX daemon.info ntpd[790]: 162.159.200.123 local addr 10.0.1.60 -> <null>
      Feb 9 15:08:48 RECALBOX daemon.info ntpd[790]: 2606:4700:f1::1 local addr 2001:7e8:c818:7500:ba27:ebff:fe7c:1173 -> <null>
      Feb 9 15:08:48 RECALBOX daemon.info ntpd[790]: 185.137.97.4 local addr 10.0.1.60 -> <null>
      Feb 9 15:08:52 RECALBOX daemon.notice ntpd[2073]: ntpd 4.2.8p11@1.3728-o Wed Nov 13 11:21:00 UTC 2019 (1): Starting
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2073]: Command line: /usr/sbin/ntpd -g
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: proto: precision = 0.416 usec (-21)
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: Listen and drop on 0 v6wildcard [::]:123
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: Listen and drop on 1 v4wildcard 0.0.0.0:123
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: Listen normally on 2 lo 127.0.0.1:123
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: Listen normally on 3 eth0 10.0.1.60:123
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: Listen normally on 4 lo [::1]:123
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: Listen normally on 5 eth0 [fd00::ba27:ebff:fe7c:1173]:123
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: Listen normally on 6 eth0 [2001:7e8:c818:7500:ba27:ebff:fe7c:1173]:123
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: Listen normally on 7 eth0 [fe80::ba27:ebff:fe7c:1173%3]:123
      Feb 9 15:08:52 RECALBOX daemon.info ntpd[2075]: Listening on routing socket on fd #24 for interface updates
      I stopped lircd that I do not use.
      Then I thought IPv6 may be the problem so decided to get rid of it using this tutorial : https://tutox.fr/2017/11/24/desactiver-ipv6-raspberry/ but it didn't helped.
      Windows error is related to big files transfer, but my files are really small (2MB) and I also have issues with SSH:
      If I transfer the same files on another Linux box it works perfectly fine:
      I tried to transfer from Linux to recalbox but there are still the same issues:
      bios/dc$ scp -v * root@recalbox:/recalbox/share/bios/dc
      Executing: program /usr/bin/ssh host recalbox, user root, command scp -v -d -t /recalbox/share/bios/dc
      OpenSSH_6.7p1 Debian-5+deb8u8, OpenSSL 1.0.1t 3 May 2016
      debug1: Reading configuration data /etc/ssh/ssh_config
      debug1: /etc/ssh/ssh_config line 19: Applying options for *
      debug1: Connecting to recalbox [abcd:**********************wxyz] port 22.
      debug1: Connection established.
      debug1: key_load_public: No such file or directory
      debug1: identity file /home/myuserid/.ssh/id_rsa type -1
      debug1: identity file /home/myuserid/.ssh/id_rsa-cert type -1
      debug1: identity file /home/myuserid/.ssh/id_dsa type 2
      debug1: identity file /home/myuserid/.ssh/id_dsa-cert type -1
      debug1: identity file /home/myuserid/.ssh/id_ecdsa type -1
      debug1: identity file /home/myuserid/.ssh/id_ecdsa-cert type -1
      debug1: identity file /home/myuserid/.ssh/id_ed25519 type -1
      debug1: identity file /home/myuserid/.ssh/id_ed25519-cert type -1
      debug1: Enabling compatibility mode for protocol 2.0
      debug1: Local version string SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u8
      debug1: Remote protocol version 2.0, remote software version dropbear_2017.75
      debug1: no match: dropbear_2017.75
      debug1: SSH2_MSG_KEXINIT sent
      debug1: SSH2_MSG_KEXINIT received
      debug1: kex: server->client aes128-ctr hmac-sha2-256 none
      debug1: kex: client->server aes128-ctr hmac-sha2-256 none
      debug1: sending SSH2_MSG_KEX_ECDH_INIT
      debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
      debug1: Server host key: ECDSA A2::7b
      The authenticity of host 'recalbox (abcd:**********************wxyz)' can't be established.
      ECDSA key fingerprint is A8:
      :7b.
      Are you sure you want to continue connecting (yes/no)? yes
      Warning: Permanently added 'recalbox,abcd:**********************wxyz' (ECDSA) to the list of known hosts.
      debug1: SSH2_MSG_NEWKEYS sent
      debug1: expecting SSH2_MSG_NEWKEYS
      debug1: SSH2_MSG_NEWKEYS received
      debug1: SSH2_MSG_SERVICE_REQUEST sent
      debug1: SSH2_MSG_SERVICE_ACCEPT received
      debug1: Authentications that can continue: publickey,password
      debug1: Next authentication method: publickey
      debug1: Trying private key: /home/myuserid/.ssh/id_rsa
      debug1: Offering DSA public key: /home/myuserid/.ssh/id_dsa
      debug1: Trying private key: /home/myuserid/.ssh/id_ecdsa
      debug1: Trying private key: /home/myuserid/.ssh/id_ed25519
      debug1: Next authentication method: password
      root@recalbox's password:
      debug1: Authentication succeeded (password).
      Authenticated to recalbox ([abcd:**********************wxyz]:22).
      debug1: channel 0: new [client-session]
      debug1: Entering interactive session.
      debug1: Sending environment.
      debug1: Sending env LANG = fr_FR.UTF-8
      debug1: Sending command: scp -v -d -t /recalbox/share/bios/dc
      Sending file modes: C0644 702637 airlbios.zip
      Sink: C0644 702637 airlbios.zip
      airlbios.zip 100% 686KB 42.9KB/s 00:16
      Sending file modes: C0644 21740 Atomiswave_datfiles.zip
      Sink: C0644 21740 Atomiswave_datfiles.zip
      Atomiswave_datfiles.zip 100% 21KB 21.2KB/s 00:00
      Sending file modes: C0644 34620 awbios.zip
      Sink: C0644 34620 awbios.zip
      awbios.zip 100% 34KB 33.8KB/s 00:00
      Sending file modes: C0644 2097152 dc_boot.bin
      Sink: C0644 2097152 dc_boot.bin
      dc_boot.bin 100% 2048KB 60.2KB/s 00:34
      Sending file modes: C0644 131072 dc_flash.bin
      dc_flash.bin 0% 0 0.0KB/s --:-- ETA
      Sink: C0644 131072 dc_flash.bin
      dc_flash.bin 100% 128KB 128.0KB/s 00:00
      Sending file modes: C0644 1381185 f355bios.zip
      Sink: C0644 1381185 f355bios.zip
      f355bios.zip 100% 1349KB 54.0KB/s 00:25
      Sending file modes: C0644 2315343 f355dlx.zip
      f355dlx.zip 0% 0 0.0KB/s --:-- ETA
      Sink: C0644 2315343 f355dlx.zip
      f355dlx.zip 100% 2261KB 53.8KB/s 00:42
      Sending file modes: C0644 1469423 hod2bios.zip
      hod2bios.zip 0% 0 0.0KB/s --:-- ETA
      Sink: C0644 1469423 hod2bios.zip
      hod2bios.zip 100% 1435KB 59.8KB/s 00:24
      Sending file modes: C0644 120724 Naomi_datfiles.zip
      Sink: C0644 120724 Naomi_datfiles.zip
      Naomi_datfiles.zip 100% 118KB 117.9KB/s 00:00
      Sending file modes: C0644 9308440 naomi.zip
      Sink: C0644 9308440 naomi.zip
      naomi.zip 80% 7280KB 40.4KB/s 00:44 ETA
      Write failed: Broken pipe
      lost connection
      I don't know what to try now ... can anybody help please ?
        Hello
        double post https://forum.recalbox.com/topic/20030/problème-lors-de-transfert-de-fichiers-en-http-smb-et-ssh-vers-recalbox
