    Installing drivers for GamePi43 waveshare
    GamePad/GPIO/USB encoder
    installing drivers gamepi43 waveshare
    4067
    • LianKain
      LianKain last edited by
      Hi,
      I just got my GamePi43 from waveshare.
      https://www.waveshare.com/product/mini-pc/gamepi43-acce-us.htm
      I try to install the driver following the description on the waveshare page.
      https://www.waveshare.com/wiki/GamePi43
      They also give the driver.
      https://www.waveshare.com/w/upload/6/6f/GamePi43-190717.tar.gz
      If I try to unpack the archiv or even just move it, the error msg appears that I dont have writing rights. If I try to use "su root" before the order, I get the error msg "connot execute binary file".
      Whats my mistake? How can I get the GamePi43 running.
        OyyoDams Staff @LianKain last edited by OyyoDams
        @liankain There is no su command on Recalbox OS, so your script cannot work, it must be adapted.
        LianKain 1 Reply Last reply Reply Quote 0
        • LianKain
          LianKain @OyyoDams last edited by
          @oyyodams Like I said, I used "su" not "sudo" and it seems to bring a little progress. Its just brought me to the next barrier ("connot execute binary file") but in gerneral the "su" command seemed to work.
          But what ever. The problem is Iยดm not that experienced in unix, so I need a little more detailed instructions what to do.
            @liankain sudo or su are not implemented in Recalbox. These commands are used to execute root commands as a standard user. On Recalbox, you're root all the time. That's why su root means nothing here.
            • LianKain
              @oyyodams OK, thanks for that information. So I know now what not works. ;-D
              Could you give me some clues what to do to solve my problem to install the gamepi43 drivers? ๐Ÿ™‚
              That are the instructions of waveshare, but unfortunataly it not works because root only have reading rights.
              tar xzvf /boot/GamePi43-*.tar.gz
              cd GamePi43/
              ./GamePi43
              They say I need to copy the driver-archiv in the root folder, but I also cant move the files there because of the only reading restrictions.
              • ian57
                ian57 Staff last edited by
                From your recalbox via ssh :
                wget https://www.waveshare.com/w/upload/6/6f/GamePi43-190717.tar.gz --no-check-certificate
                tar xzf GamePi43-190717.tar.gz
                cd GamePi43
                and as scripted in the GamePi43 file :
                mount -o remount,rw /
                mount -o remount,rw /boot
                mkdir -p /lib/modules/4.14.62/extra/
                cp ./recalbox/mk_arcade_joystick_rpi.ko /lib/modules/4.14.62/extra/
                cp ./recalbox/etc/modules.conf-43 /etc/modules.conf
                cp ./recalbox/boot/config.txt-43 /boot/config.txt
                cp ./recalbox/recalbox/share/system/recalbox.conf-43  /recalbox/share/system/recalbox.conf
                reboot
                That's all
                LianKain 1 Reply Last reply Reply Quote 1
                • LianKain
                  LianKain @ian57 last edited by
                  @ian57 @oyyodams It works now. Thank you both a lot.
                  I already put the unpacked "GamePi43"-folder in the "share"-folder before. So I followed your scripted steps from that point but it also worked.
                  Just for my own information and in case I not bothering you with that question, but:
                  What was the problem?
                  Why the description from waveshare not worked?
                  Why root dont got the rights to move (mv) but copy (cp) works?
                  Thanks in advance and thanks again for the help.
                  • ian57
                    ian57 Staff @LianKain last edited by ian57
                    @liankain the problem was that the Recalbox root (/) filesystem is readonly to prevent to be corrupted by a crash or a hard reboot. So you need to turn it in read-write mode to be able to copy files in it. Only the share partition is in RW. If the filesystem is in Read only mode even root cannot modify it.
                    The waveshare wiki is full of errors :)... they mixed the retropie way with the recalbox way. For example they git a login Pi with recalbox, which is not good ๐Ÿ™‚
                    • LianKain
                      @ian57 Ok, I understand. Thanks again. ๐Ÿ˜‰
                      Copyright ยฉ 2021 recalbox.com
