    Controller freezes or loses connection when entering retroarch menu
    GamePad/GPIO/USB encoder
    freezes loses connection entering retroarch
    • Bloodsurfer
      Bloodsurfer last edited by
      I'm using an 8bitdo SF30 Pro controller as well as a PS3 pad.
      Everything works fine when I start up a game, but as soon as I enter the retroarch menu by pressing hotkey + B, the controller freezes. It does not lose the connection, but no button shows any reaction anymore.
      When I then disconnect the controller and connect it again, it does work again, but not correctly. When I press up/down to choose an option, it does not go to the next menu item but skips five or six of them at a time. So the menu is unusable.
      When I exit the menu, the controller freezes again.
      Do you guys have any idea what is causing this and if I can do anything to solve it?
      It was working fine in earlier versions before 6.0. I'm now using 6.1.1 on a 3B+.
        Hello
        you need to use last firmware.
        Do you use android mode ?
        • Bloodsurfer
          Hello,
          yes, the current firmware (1.33) is already installed.
          I start it using Start + B, which means Dinput mode. That's the one which was working fine before.
