    8Bitdo NES30 Pro won't pair (again)
    GamePad/GPIO/USB encoder
    8bitdo nes30 wont pair
    • c-f-g
      c-f-g last edited by
      There used to be this issue 2 years ago, but now, when I reinstalled recalbox to the latest version, I can't pair again.
      In basic mode (on) and pair mode it finds all of my three controller, but when I want to pair then, it fails.
      I tried it a dozen times with different firmware versions on my pads (4.10, 4.00, 2.00) without a change. I tried to reset the bt pairing, as well as a factory reset...nothing.
      skankster 1 Reply Last reply Reply Quote 0
      • skankster
        skankster @c-f-g last edited by
        @c-f-g Don't mean to hijack your post, but I'm having the same problem as well. I was thinking about reinstall recalbox from scratch, have you done that?
        I have 2 SN30 Pros that were working flawlessly before 6.10 and are not working since then, even after 6.1.1.
        • BioS
          BioS last edited by
          Having exact the same problem, since I upgraded to 6.1.1 I can (manually) pair my 2 controllers but only one of them can connect at the same time.
          As soon as I switch off one controller the other one will connect instantly and vice versa.
          But not both at the same time.
          Is there a image with the 6.0 version availible?
          It's christmas time and the kids wanna play...
          • skankster
            skankster last edited by
            @bios said in 8Bitdo NES30 Pro won't pair (again):
            Hey Bios, have you tried reinstall the whole system from scratch?
            • skankster
              So: I tried to reinstall Recalbox 6.1.1 from scratch all over again. 8bitdo pairing suffering from the same problems (cant pair). Tried to pair manually via bluetoothctl, it WORKS - but does not keep paired after a reboot.
              I honestly do not know what to do anymore. Cant find older version (6.0) anywhere anymore and 6.1.1 is useless for me if I cant keep my gamepads paired.
              If someone have any solutions for this, please let me know.
