    Adding ROMs to an internal Hard drive with a USB
    adding roms internal hard usb
    • modigazzi
      modigazzi last edited by
      I have Recalbox installed on a 250 Gig internal hard drive and it works great. I have played the games that came with it. I want to now transfer roms to that same hard drive but can't figure out how to accomplish it. I would love to stick my USB into my windows system, transfer the roms then plug it in to the recalbox machine and see a pop up on the screen that says (would you like to transfer these roms onto your hard drive), but I guess that's not going to happen.
      Modigazzi
        paradadf Staff @modigazzi last edited by
        @modigazzi you can easily use the file manager inside kodi to copy your roms with an user interface.
        modigazzi 1 Reply Last reply Reply Quote 0
        • modigazzi
          modigazzi @paradadf last edited by
          @paradadf Thank you so much I will try to do that.
          Modigazzi
          100.7k
