    RB 6.1.1 - MSX1 in DSK format NO WORK
    6.1.1 msx1 dsk format
    2046
    • Koala2000
      Koala2000 last edited by
      Hello. I have a problem.
      I have installed Recalbox 6.1.1 on a Raspberry Pi 3 since 0 and everything goes smoothly.
      The problem is that, with all the BIOS installed and correct, the MSX emulator fails.
      Specifically, with the games DSK format of MSX1.
      All other formats (MSX - Cartridges and MSX2 - Cartridges and Floppy Disks) work perfectly.
      When I try to run any MSX1 game in DSK format, the emulator restarts again and again without running the game. This did not happen in previous versions of Recalbox.
      Do you know the reason and can you help me? THANKS
      paradadf iosman987 2 Replies Last reply Reply Quote 0
        paradadf Staff @Koala2000 last edited by
        @koala2000 I don’t have time to test it right now, but nothing on the emulator has changed betwen 6.1 and 6.1.1, so I suspect it must be something else.
        Neither bluemsx nor fmsx need the addition of any bios files anymore, as they’re bundled with the emulator. If you have changed any bios or configuration ini, I’d suggest to delete the Machines folder inside the bios directory and copy it over from share_init or download them from libretro’s github page.
        • Koala2000
          Ok I'll try. I did not get to test version 6.1, I went from 6.0 to 6.1.1 directly.
          And I'm sorry, I asked the question in two languages ​​in case someone didn't understand me.
          Thanks for your help.
          • iosman987
            iosman987 @Koala2000 last edited by
            @koala2000 said in RB 6.1.1 - MSX1 in DSK format NO WORK:
            Set the audio bitrate to 256 kbps and the sampling rate to 44100 Hz. Thanks
            Koala2000 1 Reply Last reply Reply Quote 0
            • iosman987
              iosman987 last edited by
              @iosman987 said in RB 6.1.1 - MSX1 in DSK format NO WORK:
              thanks my issue has been fixed.
              • Koala2000
                Koala2000 @iosman987 last edited by
                @iosman987
                Where I have to do it? I don´t know. Very Thanks.
                • batjuancrespo
                  batjuancrespo last edited by
                  I have the same problem... Any help, please?
                  101.4k
