    Split MAME Into 2 Separate Folders & UI Feature Request
    Your recalbox
    split mame separate folders feature
    • tdelios
      tdelios last edited by
      Are there any plans to separate the MAME rom folder from one into two. One for the Libretro and one for the ADVANCEMAME and update the UI to have two sets of MAME.
      Just find a bit of a nuisance to dump all my mame roms into one folder and then go into the Advanced settings-->Advanced Emulator Configuration-->mame and flip it from one emulator to another based upon which of the two the game runs on.
      • Bkg2k
        Bkg2k Staff last edited by
        https://recalbox.gitbook.io/documentation/v/francais/utilisateur-avance/surcharge-de-configuration
        Currently only available in French, use google-trad 🙂
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @Bkg2k last edited by
          @bkg2k
          this requires manual changes to be done in recalbox.. Any plans in a future release to have this already done from a simple UI menu selection?
          • Bkg2k
            Bkg2k Staff @tdelios last edited by
            @tdelios Just a single file per MAME version/folder, a lot less annoying than changing the core for every single game using the UI menus.
            And no, there is no plan to split MAME into version.
            Recalbox is currently supporting AdvanceMame, MAME2000, 2003, 2003+, 2010 and 2015 (maybe more in the future). It would be even more confusing than having a single folder.
