    How to play PC-Engine cd?
    Emulator Arcade/PC/Console
    play pc-engine
    3062
    • kc870378
      kc870378 last edited by
      I am new user, and I have converted my cd game into cue, bin file. But it cannot run. Please help!
        Hello
        PCEngine CD require bios, check your bios file intro recalbox manager.
        check readme.txt in bios folder.
        kc870378 1 Reply Last reply Reply Quote 0
        • kc870378
          kc870378 @acris last edited by
          @acris
          I check bio file, it already have syscard3.pce but still not work
            Scavy Global moderator @kc870378 last edited by
            @kc870378 Is it exactly this one ?
            ff1a674273fe3540ccef576376407d1d syscard3.pce
            • kc870378
              kc870378 @Scavy last edited by
              @scavy
              I don’t know is that or not. When I run game, the display show read error
              kc870378 2 Replies Last reply Reply Quote 0
              • kc870378
                kc870378 @kc870378 last edited by
                Checked, yes
                • kc870378
                  Basical when i want play game, it only show load error
                  • nayok
                    nayok last edited by nayok
                    Hi,
                    if your bios is ok,
                    Your game files are supposed to be split in 3:
                    .ccd, .img, .sub
                    or
                    .bin, .cue, .srm
                    That said, to get a better help from the community, you are supposed to specify your system settings:
                    hardware
                    recalbox version
                    controller setup
                    games storage used
                    Rpi 3 B+
                    Recalbox 9.1
                    Usb Storage
                    USB Xin-Mo controller
