    Solved Games load very slow Dragonblaze 6.1
    very slow dragonblaze 6.1
    2949
    • Styrkjar
      Styrkjar last edited by
      I´ve got an interesting issue here. Everything works fine, as long as I´m using Joypads without Bluetooth.
      As soon as I´m connecting my 8bitdo Controller via BT it takes about one Minute to start a Game. Everything else still works fine. The Menu wokrs well and the Games run without any lag. The only problem comes, when I´m starting a Game. The Screen goes Black for about one Minute, after that the Game starts and works normal.
      To make things really complicated: This problem doesn´t effect Dreamcast Games. When I´m restarting EmulationStation withour connecting my BT Gamepad, everything is fine again and the Games start in an instant.
      Does anybody know the reason for this, or even better: can provide a solution?
        Scavy Global moderator @Styrkjar last edited by
        Hi @styrkjar
        The bluetooth module is currently updating by @OyyoDams, it may solve your problem. It will be included in the coming-soon recalbox release, v6.1.1.
        Your controllers are 8bitdo, which modeles ?
        Styrkjar 1 Reply Last reply Reply Quote 0
        • Styrkjar
          Styrkjar @Scavy last edited by
          @scavy I'm using the SF30 Pro
          I haven't tested other BT-Controllers yet. I'm just wondering if I'm the only one with these issue...
            @styrkjar I'm using the same controller as yours. I don't have this issue. Is your controller connected in Android mode ?
              Scavy Global moderator @Scavy last edited by
              @scavy said in Games load very slow Dragonblaze 6.1:
              I'm also using PS3 and PS4 official controllers, it works fine also with the BT mode.
              • pmroyo
                pmroyo last edited by pmroyo
                Hi @styrkjar.
                I have the same issue with my SN30 PRO. No problem with a generic USB gamepad but when using SN30 pro it takes more than 30 secs loading the game. I am charging my 8bitdo ZERO in order to test, will come to you with the results
                  8 Bitdo need to use D-input not x-input
                  with x-input mode -> slow
                  • Styrkjar
                    I ised the 8bitdo Controller for quite a time without any issues. This started suddenly, after reconnecting it.
                    Maybe it's just a faulty device, bit even then, the Bug is quite strange...
                    • pmroyo
                      @acris I have always used X-input and no problem at all until this new version of recalbox. D-input is for android according to the manual
                        @pmroyo
                        lot of change in new version of recalbox
                        Please use D-input , configure gamepad, and try again.
                          Scavy Global moderator @pmroyo last edited by
                          @pmroyo said in Games load very slow Dragonblaze 6.1:
                          You have to use the Android mode for RCB (D-input). I'm using this one according since i got my controllers (and snice the 4.1 release), it works perfectly (no BT disconnection and no lag).
                          And as @acris said, don't forget to configure your controller.
                          • pmroyo
                            Thanks guys, I have change the pair mode to android in my 8bitdo ZERO and SN30 PRO and the issue has been solved.
                            • Styrkjar
                              Thanks a lot. This solved the Problem.
