    Galaga on mame fail to launch
    Emulator Arcade/PC/Console
    galaga mame fail launch
    4790
    • pelletalexandre
      pelletalexandre last edited by
      Hello
      On recalbox 6.1, so with Mame 0.78, i try to launch galaga.zip and it doesn't work.
      This is the log i got in es_log.txt :
      [2019/11/05 11:59:14.755] (INFO ) : Attempting to launch game...
      [2019/11/05 11:59:14.756] (INFO ) : Shutting down SDL AUDIO
      [2019/11/05 11:59:15.157] (INFO ) : Available and configurated : Mega World
      [2019/11/05 11:59:15.158] (INFO ) : No config for player 0
      [2019/11/05 11:59:15.158] (INFO ) : So i set Mega World for player 0
      [2019/11/05 11:59:15.158] (INFO ) : No config for player 1
      [2019/11/05 11:59:15.158] (INFO ) : No config for player 2
      [2019/11/05 11:59:15.158] (INFO ) : No config for player 3
      [2019/11/05 11:59:15.159] (INFO ) : No config for player 4
      [2019/11/05 11:59:15.159] (INFO ) : Configure emulators command : -p1index 0 -p1guid 03000000b50700000399000000010000 -p1name "Mega World" -p1nbaxes 2 -p1devicepath /dev/input/event0
      [2019/11/05 11:59:15.159] (INFO ) : Controllers config : -p1index 0 -p1guid 03000000b50700000399000000010000 -p1name "Mega World" -p1nbaxes 2 -p1devicepath /dev/input/event0
      [2019/11/05 11:59:15.325] (INFO ) : python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc -p1index 0 -p1guid 03000000b50700000399000000010000 -p1name "Mega World" -p1nbaxes 2 -p1devicepath /dev/input/event0 -system mame -rom /recalbox/share/roms/arcade/galaga.zip -emulator default -core default -ratio auto
      [2019/11/05 11:59:18.553] (WARN!) : ...launch terminated with nonzero exit code 256!
      So, can someone tell me what's wrong this that. The rom cames from the romset mame 0.78.
      Thanks.
      Alexandre
      barbudreadmon OyyoDams 2 Replies Last reply Reply Quote 0
      • barbudreadmon
        barbudreadmon @pelletalexandre last edited by barbudreadmon
        @pelletalexandre said in Galaga on mame fail to launch:
        Maybe you are using your 0.78 romset with an emulator which is not the mame2003 libretro core ? Otherwise it would mean the game is broken with mame2003 (no idea if that's the case), or your romset is not 0.78 actually.
        On a sidenote, the game works flawlessly on FBNeo with the latest romset (0.215).
        Libretro developper :
        • FBAlpha FBNeo (Arcade)
        • Kronos (Sega Saturn/ST-V)
        • YabaSanshiro (Sega Saturn)
        pelletalexandre 1 Reply Last reply Reply Quote 0
          OyyoDams Staff @pelletalexandre last edited by OyyoDams
          @pelletalexandre try to download it from another location
          • pelletalexandre
            pelletalexandre @barbudreadmon last edited by
            @barbudreadmon
            By default, Recalbox 6.1 doesn't come with mame 0.78?
            I just upload the galaga.zip in the mame folder, so i was thinking that Recalbox handle itself the game list with the right emulator?
            Do i need to edit that file to force another emulator?
            This the romset i downloaded : MAME2003_Reference_Set_MAME0.78_ROMs_CHDs_Samples. Is that good?
            Thanks
            • barbudreadmon
              It comes with mame2003 which is mame 0.78 indeed, however i don't know if it's the emulator set for the mame folder in your config.
              • pelletalexandre
                pelletalexandre @OyyoDams last edited by
                @oyyodams
                I was thinking about it, but, i doesn't find another place to get it...
                Everyone says it easy but i not.
                • pelletalexandre
                  @barbudreadmon
                  this the mame section in es_sysytems.cfg. This is the default one and it seems good :
                  <system>
                  <fullname>Mame</fullname>
                  <name>mame</name>
                  <path>/recalbox/share/roms/mame</path>
                  <extension>.zip .ZIP</extension>
                  <command>python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc %CONTROLLERSCONFIG% -system %SYSTEM% -rom %ROM% -emulator %EMULATOR% -core %CORE% -ratio $
                  <platform>arcade</platform>
                  <theme>mame</theme>
                  <emulators>
                  <emulator name="libretro">
                  <cores>
                  <core>mame2015</core>
                  <core>mame2010</core>
                  <core>mame2003</core>
                  <core>mame2000</core>
                  <core>mame2003_plus</core>
                  </cores>
                  </emulator>
                  <emulator name="advancemame">
                  <cores>
                  <core>advancemame</core>
                  </cores>
                  </emulator>
                  </emulators>
                  </system>
                  • barbudreadmon
                    idk, it doesn't contain information on the emulator you are using, just a list of the emulators you could use for this folder.
                    • pelletalexandre
                      @barbudreadmon
                      Ok, so when i launch a game, how recalbox knows which emulator he needs to use?
                      For example, i uploaded street fighter 2 the same way and it works fine without doing anything.
                      What do i need ti do?
                      Thanks
                      • barbudreadmon
                        it's somewhere in the configuration menu, can't remember where exactly
                        • pelletalexandre
                          @barbudreadmon
                          Big thank to you. It was just about setting mame 2003 instead of mame 2003 plus...
                          So, it is all right.
                          Thanks again!
                          • barbudreadmon
                            It seems there are a lot of things that got fixed in galaga after mame2003/0.78, that's why mame2003-plus uses a more recent version of the driver, which needs a more recent version of the romset (probably mame2010/0.139). From what i'm seeing in the mame changelog, i wouldn't recommend using mame2003/0.78 to play galaga.
                            100.9k
