    Recalbox 6.1 DragonBlaze does not launch games on Odroid XU4
    recalbox 6.1 dragonblaze does launch
    • BlackHoleVR
      BlackHoleVR last edited by
      I have just installed the latest Recalbox 6.1 Dragon Blaze version on Odroid XU4.
      Everything looks OK but no game starts when i launch it.
      Do you have any ideas?
      • BlackHoleVR
        From /recalbox/share/system/logs/recalbox.log
        [ 7.42] ---- recalbox-config.sh ----
        [ 7.43] setting audio volume : 40
        [ 7.48] Setting volume for numid=1
        [ 7.40] amixer: Control default element write error: Operation not permitted
        [ 7.40]
        [ 7.50] Restoring ALSA mixers configuration
        [ 7.52] setting audio to [0:0] Odroid-XU4 - Odroid-XU4 + Primary multicodec-0
        • BlackHoleVR
          From /recalbox/share/system/.emulationstation/es_log.txt
          I found 2 errors see below.
          [2019/11/03 11:11:54.380] (ERROR) : VolumeControl::init() - Failed to find mixer elements!
          [2019/11/03 11:11:54.395] (ERROR) : MUSIC Error - Unable to open SDLMixer audio: ALSA: Couldn't open audio device: No such file or directory
          [2019/11/03 11:11:53.024] (INFO ) : Attempting to launch game...
          [2019/11/03 11:11:53.024] (INFO ) : Shutting down SDL AUDIO
          [2019/11/03 11:11:53.024] (INFO ) : Available and configurated : Logitech Logitech Cordless RumblePad 2
          [2019/11/03 11:11:53.024] (INFO ) : Saved Logitech Logitech Cordless RumblePad 2 for player 0
          [2019/11/03 11:11:53.024] (INFO ) : No config for player 1
          [2019/11/03 11:11:53.024] (INFO ) : No config for player 2
          [2019/11/03 11:11:53.024] (INFO ) : No config for player 3
          [2019/11/03 11:11:53.024] (INFO ) : No config for player 4
          [2019/11/03 11:11:53.025] (INFO ) : Configure emulators command : -p1index 0 -p1guid 030000006d04000019c2000011010000 -p1name "Logitech Logitech Cordless RumblePad 2" -p1nbaxes 4 -p1devicepath /dev/input/event2
          [2019/11/03 11:11:53.025] (INFO ) : Controllers config : -p1index 0 -p1guid 030000006d04000019c2000011010000 -p1name "Logitech Logitech Cordless RumblePad 2" -p1nbaxes 4 -p1devicepath /dev/input/event2
          [2019/11/03 11:11:53.187] (INFO ) : python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc -p1index 0 -p1guid 030000006d04000019c2000011010000 -p1name "Logitech Logitech Cordless RumblePad 2" -p1nbaxes 4 -p1devicepath /dev/input/event2 -system nes -rom /recalbox/share/roms/nes/BladeBuster\ (High\ Level\ Challenge).nes -emulator default -core default -ratio auto
          [2019/11/03 11:11:53.455] (WARN!) : ...launch terminated with nonzero exit code 256!
          [2019/11/03 11:11:53.455] (INFO ) : Creating surface...
          [2019/11/03 11:11:53.510] (INFO ) : Created window successfully.
          [2019/11/03 11:11:53.807] (INFO ) : Added known joystick Logitech Logitech Cordless RumblePad 2 (instance ID: 0, device index: 0)
          [2019/11/03 11:11:54.395] (INFO ) : playing
          [2019/11/03 11:11:54.395] (INFO ) : Mix_PlayMusic: Audio device hasn't been opened
          • BlackHoleVR
            @blackholevr said in Recalbox 6.1 DragonBlaze does not launch games on Odroid XU4:
            All emulators launch exit with RC code not equal zero. Why?
