    Issue Metal Slug 5 and Cadillacs and Dinosaurs
    Emulator Arcade/PC/Console
    issue metal slug cadillacs dinosaurs
    3909
    • mcgyver83
      mcgyver83 last edited by
      I'm running recalbox 6.1.
      When I try to start Metal Slug 6 i see these lines in log
      Powering on HDMI with explicit settings (CEA mode 4)
      Powering on HDMI with preferred settings
      /usr/bin/retroarch -L /usr/lib/libretro/mame2003_plus_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg --appendconfig /recalbox/share/system/configs/retroarch/retroarchcustom.cfg.overrides.cfg /recalbox/share/roms/mame/mslug6.zip
      running command: /usr/bin/retroarch -L /usr/lib/libretro/mame2003_plus_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg --appendconfig /recalbox/share/system/configs/retroarch/retroarchcustom.cfg.overrides.cfg /recalbox/share/roms/mame/mslug6.zip
      And the screen come back to the game list.
      Any hints?
        paradadf Staff @mcgyver83 last edited by
        @mcgyver83 that should be a neogeo game, right? Have you added the neogeo.zip bios in the roms folder next to the game?
        • cissou
          cissou last edited by
          certainly that the zip roms are not correct for the emulator you use (mame2003_plus), you have to verify them with the dat given in the roms directory and clrmamepro.
          Dell 3020M + X360 sans fil
          Bartop Modulaire : Rpi3
          mcgyver83 1 Reply Last reply Reply Quote 0
          • mcgyver83
            mcgyver83 @cissou last edited by
            @cissou Thanks.
            I'm really a newbie in emulation.
            You are suggesting me that recalbox 6.1 uses mame2003_plus as NeoGeo emulator?
            So I have to have games roms suitable for this emulator, right?
            And also I have to search for bios?
            • mcgyver83
              Hi found some romset with some games.
              Some of them works others no (just log lines like above).
              How can I verify that a rom is suitable for my emulator (example: suitable for Mama2003 plus)?
              • barbudreadmon
                barbudreadmon @paradadf last edited by
                @paradadf said in Issue Metal Slug 5 and Cadillacs and Dinosaurs:
                Metal Slug 6 is an atomiswave game, i don't know which one @mcgyver83 is using, he mentions 5 in title but 6 in his post. 6 won't run with any version of mame, you'll need flycast for this one.
                For neogeo games like Metal Slug 5, i wouldn't recommend using anything besides FBNeo, afaik FBNeo might be the only neogeo emulator with no known glitch (even current mame has some).
                @mcgyver83 said in Issue Metal Slug 5 and Cadillacs and Dinosaurs:
                @cissou told you : use clrmamepro + the dat file corresponding to the emulator
                Libretro developper :
                • FBAlpha FBNeo (Arcade)
                • Kronos (Sega Saturn/ST-V)
                • YabaSanshiro (Sega Saturn)
                cissou 1 Reply Last reply Reply Quote 0
                • cissou
                  cissou @barbudreadmon last edited by
                  @barbudreadmon there is a bootleg version of metal slug 3 which permit to run metal slug 6 on neogeo (mslug3b6.zip)
                  • barbudreadmon
                    barbudreadmon @cissou last edited by
                    @cissou thanks for the information, i never noticed this one, it seems a bit different from real mslug6 though (the player is overpowered ?)
                    • ninjaw
                      ninjaw Banned last edited by
                      Metal slug 6 bootleg has nothing to do with metal slug 6, do not play it
                      You can play Metal slug 6 and 7 on PSP (however the PI3 is now the only device not displaying menu, as it works on android & pc, but you can launch it if you know the menu)
                      You can play Metal Slug 6 on PS2 and WII when available
                      And so you can play the original metal slug 6 on Atomisware
                      • cissou
                        cissou last edited by cissou
                        I just googled it, and i wasn't aware of this, thanks @ninjaw
