    LIRC Recalbox/Kodi Infrared Remote Control not working.
    lirc recalboxkodi infrared remote control
    • farbkasten
      farbkasten last edited by
      Hello,
      i've tried to setup Infrared remote control on newest Recalbox 6.1.
      I followed this manual link text, at the second point i got stuck because when i type irrecord -H default it says: Warning: Running as Root.
      Using driver default on device /dev/lirc0
      Could not init hardware (lircd running ? --> close it, check permissions)
      Because i got stuck here, i searched for a pre-configurated lirc config file and found one for my remote model number.
      With this file the points 3 and 4 on the manual worked again. (except that irw shows every single key press 2 times)
      The remote definitely works and shows the right keys in irw (except for that double show issue).
      But in Kodi it is still not working.
      Could anyone please help me with this problem?
      Thx
      • farbkasten
        No one got any solution?
          paradadf Staff @farbkasten last edited by
          @farbkasten not many use ir remotes on kodi. Have some patience until someone that uses it see your thread.
