    Bluetooth Controller causing Kodi Network Issues
    bluetooth causing kodi network issues
    • moothead
      moothead last edited by
      Hello,   Whenever I have my bluetooth controller connected I cannot play files from my network using Kodi or they load very slowly. If I load it up with just the keyboard and the WiFi dongle connected they run fine but if I have the bluetooth dongle and controller connected they will either not work at all or they will take a lot longer to load. It was working fine before but then it suddenly started happening, I've also tried reinstalling Recalbox. Is the bluetooth interfering with the WiFi or is there a problem with Kodi's config.   Thanks.
      100.7k
