    How to add an entry in UI to run a custom script
    entry run script
    3351
    • Zemus
      Zemus last edited by
      Hi,
      At this time i didnt found an answer for this problem:
      Now that i can use Wake on Lan with the "ether-wake" command i want to add an entry for it in the moonlight section. My first guess was try to edit the gamelist.xml in the moonlight folder, but i guess the pa**er is too specific to let an sh-script through.
      Another solution could be a seperate Entry in the main menue if this is possible.
      I would be grateful for any suggestion
        voljega Banned @Zemus last edited by
        @zemus you can help yourself with the readme for my randomizer script here, should give you most of the step : https://github.com/Voljega/scripts4recalbox/tree/master/Randomizer
        just adapt everything a little bit and replace the <command> tag content by your sh command
        Zemus 2 Replies Last reply Reply Quote 1
        • Zemus
          Zemus @voljega last edited by
          @voljega Thanks for the advice! I will try it out 🙂
          • Zemus
            @voljega
            But as far i can see, this will create a whole new systemchart. For one script only it seems a bit overkill. But i will see it later at home.
              voljega Banned @Zemus last edited by voljega
              @zemus you can't do it any other way for now, or you can but it's a bit more complicated
              You'd need to add a script command called by moonlight system and then check if you are launching your sh or another thing, and redirect to the standard moonlight command if needed or do your things if it is your wake up sh script
              Anyway you can do what you want really but at least these few steps will give you some hints on how to do it
              Actually for this more evolved thing if you are not afraid of python you can look at my randomizer script it does a little bit of that
              Zemus 1 Reply Last reply Reply Quote 0
              • Zemus
                Zemus @voljega last edited by Zemus
                @voljega
                After ive got through your readme, the answer was pretty obvious:
                add a new system in /recalbox/share_init/system/.emulationstation/es_systems.cfg like this:
                <system>
                <fullname>Scripts</fullname>
                <name>Scripts</name>
                <path>/recalbox/share/roms/scripts</path>
                <extension>.sh</extension>
                <command>%ROM%</command>
                <theme>Scripts</theme>
                <platform>Scripts</platform>
                <emulators/>
                </system>
                and put your .sh scripts in /recalbox/share/roms/scripts
                for example wakeonlan.sh:
                ether-wake -i wlan0 XX:XX:XX:XX:XX
                ether-wake -i eth0 XX:XX:XX:XX:XX
                works for me. Again thanks for your help 🙂
                paradadf 1 Reply Last reply Reply Quote 1
                  paradadf Staff @Zemus last edited by
                  @zemus if you just add the .sh extension to the moonlight es_systems.cfg, wouldn’t it be enough? Maybe chmod'ing the script itself before?
                  • Zemus
                    Zemus @paradadf last edited by
                    @paradadf
                    unfortunately that doesnt work.
                    The original moonlight command interferes with it. There %ROM% is just a parameter.
                    %ROM% as standalone works.
                      @zemus yeah that's what I said that :
                      "You'd need to add a script command called by moonlight system and then check if you are launching your sh or another thing, and redirect to the standard moonlight command if needed or do your things if it is your wake up sh script"
                      if you want to integrate it to moonlight system, that is
                      • Zemus
                        @voljega
                        Ah, now i know what you mean.
                        Yeah sorry, it was late yesterday. I need more sleep.
                          @zemus no prob 🙂
