    MSX does not working after update to 6.1 (2019/09/25)
    Emulator Arcade/PC/Console
    msx does update 6.1 20190925
    • henriquewicz
      henriquewicz last edited by
      My MSX stops working in two possible cores (fmsx and bluemsx). i've checked all bios and its ok. Any idea?
        paradadf Staff @henriquewicz last edited by
        @henriquewicz did you update from 6.0 or you have a new clean installation of 6.1? Both cores should just work in 6.1 and there is no need for any addition of bios anymore, as they‘re integrated upstream and are automatically copied to the right location.
        • henrique1775
          henrique1775 last edited by henrique1775
          Hello henriquewicz, I had the same problem, I noticed that in the new recalbox version 6.1 there is no longer the "roms / msx" directory for the roms in the es_systems.cfg systems configuration file, I changed my roms + images to the roms / msx1 repository and Everything started to work.
          I hope my tip helps
          Hugs
          LCM_br 1 Reply Last reply Reply Quote 0
          • LCM_br
            LCM_br @henrique1775 last edited by
            @henrique1775 hello! I have the same problem today. Please. Help me!
