    Solved Display recalbox on a external screen and configure inputs
    display recalbox external configure inputs
    • psycus
      psycus last edited by
      Hello everyone !
      First I need to tell that I'm very new at this.
      I just installed Recalbox (6.0 DragonBlaze) on an old laptop. (on the HDD, not a USB flashdrive)
      Before that I was using Lakka but I had a major issue, my USB joystick (THT Arcade Console USB) didn't work properly.
      Both joysticks were controlling both players. I tried to solv this problem but I couldn't find any explanations that I was able to understand.
      So I tried to install recalbox to see if I had the same issue. Miracle, both joysticks are separately recognized.
      However, I have a new issue that I didn't have with Lakka, I can't use my TV as external display because there's no options in recalbox to choose the screen to use.
      I saw this post :
      https://forum.recalbox.com/topic/14772/output-to-an-external-tv-via-hdmi-or-vga-doesn-t-appear-to-be-working-with-recalbox-installed-on-pc
      To be honest, I'm really lost on the explanations. I installed WinSCP (it's the very first time I'm using it) to check if I could do something about it.
      I guess I have to type something into some file to get it work, but I don't know exactly what I'm supposed to do.
      Games work fine, sound is ok, menus are usable, but I only have the laptop display working. (1600*900)
      Sometimes I see the commands on the TV when I launch recalbox, and I was also able to see some stuff appear with KODI by changing options.
      It's just a quarter of the screen though and when I restart to go back to recalbox, it's only on my laptop again.
      (I also tried an HDMI screen to see if the problem was with my TV)
      My goal is that BOTH screens are displayed at the same time.
      Also, I have a 2nd question, how can I change the inputs for each emulators?
      I see that I can go through menus with my joysticks/buttons and change the inputs for this, but I don't know how to change the inputs in game. I'd like to have one way to control menus, and a totally different way to control inputs in game, plus a shortcut (press two buttons for more than one sec to be sure that I won't do it by mistake if possible) to go back in menus.
      I wanna play a 2X8 buttons game (SSF2T, 3 punches, 3 kicks, start, coin and sticks for two players)
      I hope everything I said was clear, and thanks for your answers. 🙂
        Zing Global moderator Translator @psycus last edited by
        @psycus Read:
        https://forum.recalbox.com/topic/18445/screen-resolution-in-tv-is-the-same-as-laptop-and-not-the-tv
        psycus 1 Reply Last reply Reply Quote 0
        • psycus
          psycus @Zing last edited by
          @zing I got some help from someone on Discord, I finally managed to do it.
          Thanks
          Zing 1 Reply Last reply Reply Quote 1
            @psycus Glad you did it! If possible, describe what you did to get registered: your question may be the question of others.
