    Lots of bugs after a long time without play and after updating to Recalbox 6
    raspberry pi 3 bug black screen pixel
    • coutoreis
      coutoreis last edited by
      So, I have a Raspberry Pi 3+ and used to play normally until Dec 2018. A few weeks ago I noticed the Recalbox 6 release and flashed it as usually. But now most SNES games are buggy: some have pixelized boxes instead of normal sprites and others gets black screen. Only a couple of games are running without any error.
      How could I troubleshot this? Is there any log that I could search for?
      I'm asking this because I don't know if this was a software issue caused after updating or it is a hardware issue (my son let the RPi fall on the floor recently and I didn't like the sound it did).
      P.s.: I already tried to redownload Recalbox and reflashed.
      P.s.2: Sega MegaDrive Sonic 2 and 3 works perfectly.
      • loak
        loak last edited by
        @coutoreis ,
        Hello, you can't update from any Recalbox before v6.0 to 6.0. Too many changes. You need a fresh install.
        Updates will be back for next versions.
        https://forum.recalbox.com/topic/17011/a-lire-processus-de-mise-à-jour. Here is a post for a safe upgrade (not update) to 6.0. It's in French but Google Translate is your friend.
        Recalbox last update
        coutoreis 1 Reply Last reply Reply Quote 1
        • coutoreis
          coutoreis @loak last edited by
          @loak so, I did the fresh install and the same errors keeps occuring. What else can I do?
          • loak
            loak last edited by
            @coutoreis
            If you did a fresh install and try with the roms and the theme provided, it may be a hardware failure.
            Try another SD card and at last an other RPI (if possible), If you have a case, Retroflag ... try without it.
            Sorry, I can't help anymore.
              Scavy Global moderator @coutoreis last edited by
              @coutoreis Hi, my snes romset works perfectly from former version to the latest. If you did a fresh install, try the different cores and see if your problem is solved or not (give us a feedback).
