    Wifi Problem.
    wifi problem
    2337
    • kalle67
      kalle67 last edited by
      Excuse me if I disturb, this problem is proposed to me, every time I start Recalbox it has to insert the WIFI password, it doesn't keep me saved, you know why?
        Zing Global moderator Translator @kalle67 last edited by
        @kalle67 What is your version of Recalbox?
        How are you shutting down the system?
        Have you tried entering the password straight into the configuration file?
        • kalle67
          The last version.
          Zing OyyoDams 2 Replies Last reply Reply Quote -1
            @kalle67 Sorry, but when someone asks for the version, never answer "The Last", many times people say they have "the latest version" and have an older version, so it is mandatory that you tell the exact version you are using.
            Also, I asked 3 questions, you only gave 1 answer and superficial. Without answers, it is impossible to help.
            kalle67 1 Reply Last reply Reply Quote 1
              OyyoDams Staff @kalle67 last edited by
              @kalle67 which board ? PC ? RPI ? Odroid ?
              • kalle67
                kalle67 @Zing last edited by
                @zing Sorry you're right, I have a raspberry Pi3b +, if I connect via cable no problem, if I connect with wifi every time the system starts up again I have to enter the password.
                  Zing Global moderator Translator @Zing last edited by
                  @kalle67
                  kalle67 1 Reply Last reply Reply Quote 0
                  • kalle67
                    @zing The version of the Recalbox is 6.0, I restarted the system many times but it always makes the same error, I also tried to enter the password directly in the configuration file, but it always returns the default one.
                      @kalle67 please check your recalbox.conf file, you may have duplicate wifi entries.
                      • kalle67
                        kalle67 @OyyoDams last edited by
                        @oyyodams said in Wifi Problem.:
                        Thanks try to check.
                        • kalle67
                          Nothing to do, I tried everything but there is nothing to do, the wifi does not work. I gave up and wired the cable.
