    Solved Emulator menu is missing most of labels
    missing labels
    2059
    • coderus
      coderus last edited by
      Hello!
      Last week i built recalbox from scratch to my rpi3 and found one problem. Emulator menu is missing most of labels
        paradadf Staff @coderus last edited by
        @coderus something must be wrong with the way you compiled it. No problem on my side.
        coderus 1 Reply Last reply Reply Quote 0
        • coderus
          coderus @paradadf last edited by
          @paradadf well, no ideas about troubleshooting? i didn't succeeded googling my case, i'll try to recompile for sure
            @coderus how could I have an idea if you haven‘t mentioned nothing else than saying you compiled it. Anyway, we have compilation instructions on gitlab and if you follow them, it will work.
            • coderus
              coderus last edited by coderus
              but what if it doesn't?
              ARCH="rpi3" git clone https://gitlab.com/recalbox/recalbox.git recalbox-${ARCH}
              not working because variable is not expanded on the same expression, it should be
              export ARCH="rpi3"; git clone https://gitlab.com/recalbox/recalbox.git recalbox-${ARCH}
              compiled with scripts/linux/recaldocker.sh
              compilation failing at
              https://gitlab.com/recalbox/recalbox/issues/941
              fixed by changing configgen version from this commit:
              https://gitlab.com/recalbox/recalbox/merge_requests/806/diffs#5a63358ecb48a0b938377fa0c5cdd211c64ef647_8_7
              flashed result image to sdcard, booted, shut down, copied psx games to sdcard, booted, started game, opened emulator menu, got bug as on picture.
                @coderus I b*mped configgen, but using the previous commit shouldn’t affect the compilation (it compiled fine before), as the change is minimal and unrelated both to a compilation fail and even less to retroarch itself.
                I don‘t understand what exact commands you are using, because you probably formatted it wrong. Also, no idea what build environment you have. If you keep having troubles, I‘d suggest to wait a couples of days until my „big b*mp“ is merged.
                • coderus
                  coderus @paradadf last edited by coderus
                  @paradadf can i build from your branch?
                  my commands are:
                  export ARCH="rpi3"
                  cd recalbox-${ARCH}
                  sed -i -e "s/RECALBOX_CONFIGGEN_VERSION.*$/RECALBOX_CONFIGGEN_VERSION = 9df8d46713c4b282943e0cd3109cb82af265afb5/" package/recalbox-configgen/recalbox-configgen.mk
                    @coderus you‘ll have to find a git tutorial online.
                    • coderus
                      @paradadf thanks, i know a lot about git, that was not the question 🙂
                      so, the problem was in regional settings. when i change recalbox language to russian this bug happens, works fine with english. closing this thread, but hope this issue will be resolved in some future 🙂
                      (retroarch psx menu works fine when russian is selected with current stable release version)
                        @coderus it is very important to give all information. Otherwise, (I don't mean it wrong) it is a waste of time. If the issue still persits once 6.1 is out, please open a descriptive issue on gitlab so it doesn't get lost in the forum.
                        • coderus
                          @paradadf https://gitlab.com/recalbox/recalbox/issues/943 done, thanks.
