    Recalbox Dragonblaze Struggling to boot emulationstation
    recalbox dragonblaze struggling boot
    • granderjoree
      granderjoree last edited by
      I have a raspberry pi model B+ currently running recalbox dragonblaze. It's connected to a VGA monitor with HDMI to VGA converter.
      My recalbox struggles in booting into emulationstation after the recalbox splashscreen ends. It just turns to black. I know it boots into emulationstation because I can hear the bg music of emulationstation. But it only shows black screen.
      When I reboot it again, sometimes it boots to emulationstation normally but sometimes it's only black screen. It's like a game of chance.
      Is Dragonblaze having trouble with a VGA screen? I noticed this only started after I upgraded to dragonblaze.
      Is there something I can do in config.txt to cure this issue?
      Thanks in advance! This forum really helps a lot.
        Zing Global moderator Translator @granderjoree last edited by
        @granderjoree said in Recalbox Dragonblaze Struggling to boot emulationstation:
        The problem is probably HDMI to VGA converter. And I do not say that specifically your model is the problem, I say that when there is an HDMI to VGA converter there are usually problems.
        101.4k
