    Adding vba next core to recalbox?
    vba next core
    3804
    • 8bit_astronaut
      8bit_astronaut last edited by
      How can i download this core? Is there a way? please help
        Why add vba-next core ?
        • 8bit_astronaut
          I had better result with vba next, for example, super mario advance 4 crash if i dont push any button in 53 seconds
            I have try super mario advance 4 (europe) (rom no-intro) , no problem. Do you have try a another rom ?
            • digitaLumberjack
              Could be nice, now that we have core selection in ES 🙂
              • 8bit_astronaut
                I mean, there's even the meteor core that just suck compared to others. It would be great to add that core, like the snes 9x core, its just great compared with the default one. Acris, i tried the rom 1.1 (usa) of super mario advance 4, i will try with other roms
                • uniQ168
                  uniQ168 last edited by
                  Would also like to see more cores in recalbox or some hint how to manually add cores from libretro. 🙂
                  Is there a way to do it?
                    paradadf Staff @uniQ168 last edited by
                    @uniQ168 of course!
                    https://github.com/recalbox/recalbox-os/wiki/Compilation-&-Modifications-(EN)
                    The recalbox team loves pull requests on github!
                    uniQ168 1 Reply Last reply Reply Quote 0
                    • uniQ168
                      uniQ168 @paradadf last edited by
                      @paradadf Thanks, I'll look into it.
                      Might I also ask how up-to-date the current (4.0.0) libretro libs are? Is it worth updating them on my own or are they frequently updated?
