    Solved 6.0 Dragon Blaze "es_systems.cfg" missing
    6.0 dragon blaze essystems.cfg missing
    • fonzman
      fonzman last edited by
      I am missing the file .\share\system.emulationstation\es_systems.cfg
      this file defined which emulator or file types get used for the different platforms. It was able to edit this file to, for example, exclude certain file types from the automatic detection (important for PSX-games with individual audio track files, so they are not scraped multiple times) or for defining specific emulator cores for certain platforms (I did that for MAME, so i could combine my arcade and neogeo collections)
      Has es_systems.cfg just been relocated or was it removed from the new release on purpose?
      • Bkg2k
        Bkg2k Staff last edited by
        This file is located in share_init, not in share
        • fonzman
          Ah, so it was relocated! Perfect, will test this as soon as possible!
          • fonzman
            File found. Edited. Everything fine! Thanks again for the help!
            • Bkg2k
              This file has bien un share_init since the begining of recalbox 🙂
              Never been relocated.
